Are you from that area Wilch?
Coming to the UAS dyno day?
Heya Blitz, yep I'm from that area :P.
There's a UAS dyno day?? I guess I should check out the events section more often!!! (checking now)
wil..
Nah we just threw a low klm second hand engine in, runs nice now its got shiney new coil packs.
And anyone looking for a purty blue skyline, its still for sale :(
Interesting point about a 350z too, they run same sized front discs as the r32 gtr :)
GTR Coil Pack BRO!!!
GTR coil packs only work for a short time in GTS-t's - the resistance from the igniter pack and ECU are diffenent - If you use GTR coils in a standard GTS-t you can kiss you ECU and igniter goodbye within a month ........
