]']Saw a black R34 GTR on old northern road towards the wisemans area
plates RUFGTR (i think) u on here? nice GTR mate...
i was in the white r32 GTR that looked at ya..as i was on coming..
i also spotted this last night turning onto M2
yummi :wassup:
Spotted : a blue r32 gtr on batt st, South Penrith. Plates MIDN9T.
Also saw a black r33 in the Croydon 7-11 service station a few days back. And a maroon r33 gtst outside Penrith RSL club, 400r front bar, 3 spoke rims, silver mesh in the front bar.
spotted: ECR 33T this morning on windsor rd near baulkham hills....
sam the new rims look awesome.......
werent you going to go wakefield today ?
Spotted Shonen today :D
ThanX mate your's look great too. I was going to go to wakefield but pulled out so I can go to Oran park on Sunday for the UAS track day
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
