that was me!!!!!! nooooo!!!!!!!!!!!!!!!!!!!! :) i should have tried to chase you down :mad: but yeah... as wilchy said we first thought you were cops, then by the time we realised you were skys i'd already gone past the split road bit, and it was too late to do a u-turn :mad:
you suck andrew!!!! :D
:mad:
spotted a few skylines
silver r33 at dural hungry jacks, white one at the same place, a black R34 gtt near dural (i was turning right)
let me guess - moanie, shonen, and... who's white one? wasn't me... who have you replaced me with!! :cheers::rant:
might have been moanie, shonen and liz (or unknown)
But there's beef at hungry jacks.... hmmm
hehe
that was me!!!!!!  nooooo!!!!!!!!!!!!!!!!!!!! :rant:  i should have tried to chase you down :( but yeah... as wilchy said we first thought you were cops, then by the time we realised you were skys i'd already gone past the split road bit, and it was too late to do a u-turn :)
you suck andrew!!!! :cheers:
:D
Awe. Come on. Don't be like that Moanie. At least I finally spotted you!
You should have chased us down! You suck :D
hahaha... yeah, thats a good point!!! you hesitated in that street.. looked like you were deciding which way to go.. then you turned the other way :cheers: soooo ssaaadddd!!!!!
i was so tired as well!!! and not knowing who you guys were i thought against a chase!!! dammit! i decided wrong!!!!!!! next time! :rant:
4 door r33 on Friday morning, bout 8:40am Warringah Road near Jamison Square. Just saw the back lights.
2 door r32 HCR-032 Warringah Road just near the speed camera bout 2:30pm grey or black one with a few stickers. SAU member I think.
4 door r32 Forestway Shopping Centre Sunday bout 3pm. Green P plates and looked like it had just come from compliance/car yard. Grey.
why do you think its a guy?!?!! pink neons!!! it must be a girl! :(
spotted a weird colour 33 on victoria rd this morning... just after the iron cove bridge... at about 10ish?! anyways.. can't remember the colour.. it may have been an off orange or green or something.. with a black cfb... looked... interesting....
Guest
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
