Ok as most as most of you guys know recently i had to change my Lower Control Arm and Caster Rod, after getting a new set of tires, alignment and suspension check the car is starting to pull to the left (if I let go of the steering wheel it will just start going to the left) I was wondering what you guys think it is, it drives fine i took it to the midnight cruise with no dramas but its worrying me for the Buller cruise. Does anyone know of a good suspension specialist near Caulfield East? After a close examination I think I've tightened the LCA bolt too tight but it seems to be stuck now (It free spins, no amount of untightening or tightening makes it move) I'm currently getting another bolt from the guy I bought the LCA from but I just haven't had the time (as he lives in Frankston) although I dont think it will have a major influence on the steering will it?
Any input appreciated
EDIT: I have to keep the steering wheel slightly to the right for it to go straight
https://www.sau.com.au/forums/topic/294690-car-pulling-to-left/
  • Replies 40
Maybe they didn't align it probably? Because if problems was with the things you install, wouldn't the car sway left when the steering wheel is straight? It's just a guess lol
But I'd hate to see you fall off the mountain next weekend :down:
its meant to veer to the left ever so slightly if you take your hands off the wheel
its a safety feature designed to make you not run onto the wrong side of the rd
just check how much - if in doubt goto a wheel balance / suspension place
Could it potentially be your tie rods? Even after an alignment, the settings won't stick if your tie rods are porked.
Suggest you get those looked at.
A nice place to go around East Caulfield; perhaps Pro Tek tyres? They're located on the corner of Ferntree Gully Rd and Dandenong rd. If not there, you can head down Nepean Hwy towards Nissan Brighton. Theres a place directly across from there but I'm not sure of the places name.
Good luck.
Actually, thats true. Because the roads are made to be on an angle, so water and stuff rolls off to the side. There's one way to test it, is to drive in the middle of the road (of course when there's no cars), then let go off the steering wheel lol.
Good luck.
ProTek and tierods/ends.... sounds like a plan.
Will pull to the left on most roads due to the slope, if you run a little more castor on the left i think it is it drives straight on cambered roads.
also take into consideration tyre condition and inflation, make sure they are all even,
and possibly brakes dragging or handbrake being overadjusted on the left side
or even a dodgy wheel alignment, these 4wsteer systems need experienced ppl to do them right.
could be a stuffed Tie rod since you hit it hard enough to bend an LCA
did you get an alignment print out from the aligner,
as some places will just say, we made it as straight as we can, without showing any printouts with all the alignment settings
Yea man Nathan gave me the alignment print out but I dont know about this stuff, I'll go get it and post it up here to see if anyone know about it
Some comments the mechanic left after a comprehensive check:
Play in L/H Front King Pin
Play in L/H rear tie rod end and upper control arm joint
L/H ball joint rubber cover split
sounds pretty serious..........
2deg less castor on the left than right, 2mm less toe on left than right, 1deg less neg camber on the left. Normally when they can't adjust camber and castor atleast get the toe equal side to side... Take it somewhere that can give advice when they see the camber/castor is out that much with no adjustment IMO.
i see this as the issue. the .3 of a degree difference in camber on the rear is insignificant compared to the fronts overall differences.
yeah i agree with ryan,
all you have to do is just look at the final values column and compare left to right
The values should be very similar left to right
your front end is showing some major differences
take it to a suspension specialist and see if they can fix it using factory adjustments
otherwise, the problem lies deeper within the suspension mounting points which could have been damaged in the accident, or possibly a bent hub
Are you running standard (stock) suspension setup?
If you are - try to find the factory manual - it seems to have all the correct angles (specs) etc. and send it to the wheel/suspension place.
Then take the car for a run on the freeway.
Ok well the story is that I brought the car to ProTek where they said (after looking at the alignment sheet) that he thinks the guy wasn't exactly the most capable but in his defense he said that he thinks the whole suspension has been pushed back and in a bit, his suggestion was to bring it to pedders and get an aftermarket setup that would allow me to adjust and compensate for the damage, or to bring it to a specialist and see what they can do. He recommended me to Kents but of course every time I hear "panel beater" there is only one real name that comes to mind when operating on a budget (Vu) so the car is now with Vu @ DT Panels and hopefully he'll be able to get it fixed with no real dramas and at a good price
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
