Update on progress for the NSW Club
Up for sale is floor carpet for an R32 Skyline sedan. It was removed from a GTS4, however can fit GTS-t. It's just a bit wider at the drivers side floor tunnel area. Great condition and I have just freshly cleaned it with a wet vac. Asking $290 negotiable, located in Newcastle, NSW.
ooft... what a turbo, does it dose? lol -
Hi, where did you manage to get 32mm release bearing carrier, it's really hard to find one in NZ . I have sort of same setup with xtreme twin plate clutch kit. I have 19mm release bearing with 18mm carrier measured back of bearing to where fork sits but it isn't enough ,it hardly touches fingers once fork pushed all the way back, I measured out and find out I'm short of 18mm. Thanks
@PuReOwNaGe There are rules for for sale adverts. You should read them and comply. There is also a proper forum to do so, rather than just in the regional fora. You won't be able to edit this particular thread, but you should start a new one, following the rules and then report this one so it can be deleted. I'm going to report it myself and delete it myself if I don't see these things happen, anyway.
