stu - probably no point entering the production car (depending on the regs). happy to drive your car for you though, I reckon it would surprise a few with it's times. but don't forget an event like this really needs you to buy tyres for the purpose ie soft compound that are unlikely to last the whole day.
It was the same at Mt Buller and the Supersprint Nationals before - even big cars like skylines running on medium and medium/soft compounds because you only need to do a lap or 2 at a time.
I still haven't seen regs posted so I assume they are more focussed on obtaining overseas competitors than getting local/amatuer entrants
  • Replies 1.4k
Posted Images
I saw the rules on their website a couple of weeks ago... Pretty much unchanged from last year from the brief glance I had.
I was wondering whether any of you guys have previously run at Superlap and could assist me in understanding the rules/limitations of the club sprint class?
The car has to be rego'd but doesn't require a log booked cage? Wings & aero changes are OK? Wheels are free but the tyre choice rule seems like it will be the trickiest one to deal with. Any suggestions on what people have run in the past?
I can post up some proposed car specs if that helps.
Jess - I could do that too - some sort of official work :P
fly510 - clubsprint class needs to have a treadware rating no less than 100. So Falken rt615's or 215's, KU36's, Federal 595 ssrs (??)
Jess - I could do that too - some sort of official work :)
would be awesome if you could...Get all up close and personal with the action...Plus your a mad flagging skills!!! :P Love your work! :blink:
im pretty much after advice from those who have had the experience previously as well!
Might seem like a newbie question but reading the CAMS standards, if i was to enter Clubsprint Class do i require a rollcage?
From looking at schedule A of the CAMS requriement
be fitted with a safety cage as required by Schedule J (refer to “General Requirements for Cars and Drivers” in
the CAMS Manual of Motor Sport);
im pretty sure looking at the pics from previous years i dont see cages in some of the cars.
To put it short - WHAT DO I NEED TO DO to my street driven car to enter the club sprint class of superlap -
or dont even bother?
Cheers
Steve
just turn up and make sure your car is safe.
you'll need tyres that have treadware rating no less than 100. roll cage not needed. you'll need full interior too for clubsprint (unless u have a cage)
fire extinguisher is needed.
umm...long sleeved clothing. pretty much same as a normal supersprint.
no worries, so your going for a look then?
I can get tyres as local Bob Jane has agreed to supply them for some signage, just have to do some more logging to finish tune, oh and put gerabox back in, have reverse gear scattered all over my bench. ill get it running and maybe we can do a practice day to set it up.......see what you reckon.
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
