  • Replies 1.4k
Posted Images
Hehe, good to read you are knocking on the door of 49s. The easiest place to make time is obviouly turn 1, but also turn 10 and 11. Straight line it, use plenty of kerb and try not to brake a lot for turn 10, rather wash off speed in turn 10 rather then before it, turn in late and really straight line your braking for turn in to 11. Lots of good time to be made through there and its quicker then you think....but as always, baby steps, the concrete is closer then you think and i have seen cars go in :)
Those watching and epecially those competing...you all SUCK! :D
Cant wait to get out there tomorrow.
There are some crazy times being done by a lot of cars, Civic's in the 41's, 180SX in the 41's plus all the hi-po cars we expected.
Hope ALL the cars get their stuff sorted - it's going to make for some awesome viewing.
There was so many close calls on turn 1, white WRX lost it, gold crapadoor ute lost it(leaf springs puff when will people learn) spun the car back close to the left side concrete wall and somehow managed to miss it, red evo had almost the passengers side rear tire in the air.
And the s15 that lost it past turn 9
Having a blast!
Car's I am driving.
S2000 is getting faster. Hopefully do sub 40's tomorrow.
Lotus is having a couple of little issues. On the Dyno as we speak, and hopefully do sub 40's also.
Honda Civic did a 42.0 which is great for a fwd na.
Benny's Civic is Supercharged and did a 41.2 which is also awesome for a front driver.
Pulse Evo is an 8 with over 400kw atw, good diffs, tyres, light and a top steerer :)
Edited by Bozman1
Great job everyone!
Good to see such a high level of performance cars there!
Best of luck tomorrow for all drivers and teams!
Hopefully this rain holds off for a couple more quick times..
Ill see you all tomorrow
heres a few shots from today... took 250 of them.. so theres many more to go through.
and finally
Holy shit mate you must have been right next to the group of SAU guys at one part of the day at the last corner haha. Did you see the silver commodore near the coke stand? There was a group of us there basically all day
Had a great day, great viewing and good company.
Sooo many top notch entries. All the internationals are something else.
Unfortunately even on a good day we are 3sec away from them.
Good luck to Mark and Russ getting the 34 sorted, RIP to the 32 :)
Turn 12 is were its at boys and girls, be there!
gold crapadoor ute lost it(leaf springs puff when will people learn)... The ute actually is irs junior and runs coil springs. Wasnt doin too bad and wasnt the slowest car today. Not my car though just thought id clear that up for ya ;-)
sure, should do some investigation before, thanks for pointing that out.
Troy,,,who died and made you the expert. You forgot about the correct turn into 2 which sets up 3 so you carry great speed down the hill to 4 which sets the car up for 5 which is flat stick. enough help from me.
Go the Rotary's in the top 5,,,very cool.
Stuarts doing great,,,15th,,,I'll bet he''s happy so far.
Neil.
I'm so glad I came from Adelaide for this, having so much fun. Was good hanging out with some well known gtr guys. Can't wait for tomorrow.
David (beer baron) I'll post up the pick with u and Tarzan Sunday night when I'm back in adelaide.
Cheers.
Settle down! Nobody has died, and nobody has made me the expert. My quickest lap around there in my car is a 1:56!. :D: What i do know is that i have driven Russ's car, i know he is a good punter and i know where i found time in my car, a very similar car to his. Its only advice. Fark man! :) Turn 2 is a slow turn and you dont make time there, you can only lose it by trying to make it! :D
How about turn 1, then turn 2, 3 is pretty important that leads you into 4 which sets you up for 5 then have to get brakign sorted for 6 as that dicates your exit and then you have to think about turning for 8, which means the sooner you wind off lock then you can get back on the power for the brief blip up to 9, then 10 leads into 11 then 12...get that all right and you shoudl be close to quick! :)
yep... i was sitting right next to you guys on a picnic blanket, until there was movement, then i ran down to the fence.... heck, i even came and asked you's about the barbecue tomoz to make sure i had sorted somewhere dry to be in the morning :) haha... spose i should have introduced maself... but thats just lame...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
