  • Replies 1.4k
Posted Images
OK, i just can let this go.... so what is the story behind this pretty serious looking piece of kit?
Thanks to MaTBoY from photography section od SAU
Is it possibly the old Performance Metalcraft R33, that used to be yellow and have signage of som evineyard...just with a colour change??!! WOnder what happened to that car, it an twin 2835s or something and had plenty of kit
its a custom built RB32 from signature performance in Ipswich, Mick built it and drives it and has had it for the 3 or 4 years i have known him. Noel knows more about power figues and the like but it is very impressive. He had a lot of trouble getting the power down
Not sure what boost/power he was running at superlap but it has made 650rwhp on 21psi but around QR he only runs alot less boost due to wheelspin (which I believe is around 400-450rwhp).
I'll tell him about this thread this afternoon as he's tuning my car atm.
Its a work in progress. Mik had this car running some quite handy times at time attack.
An 11th hour decision to upgrade for super lap saw about 2 months of the most intense upgrades you could imagine.
Home made carbon fibre doors bonnet etc, Dog box, chromolloy cage, weight reduction and so much more.
Unfortunately time was against them and the car lacked development time to get the handling side properly sorted.
It augers well for next year however with all the hardware in place and a superlap visit under the belt I think you can expect much bigger and better things from this team next year.
anyone notice all the steam inside the r34 in the photo on the last page! hahaha
and water coming out the sill
Have a look just ahead of the right rear wheel in this photo ...
http://sphotos.ak.fbcdn.net/hphotos-ak-snc...7_4491309_n.jpg
- The Tuners Group
Edited by TheTunersGroup
Vid for those interested.....yes it is a Civic :ermm:
Fastest NA Open
Fastest FWD Open and Outright
8th Outright Open
Time 1.40.94
http://www.youtube.com/watch?v=0dnQW9MT-no
It was quick boz but i never thought I would hate the sound I hated worse than a drag rotor until i heard that f**ken noisy pos. :)
hey guys.... ive been up all night tossing and turning and thinking about next years superlap.. and my car....
why are there so many rules for Open... but Pro is invite only??
i want to move my engine back 15cm and section out the firewall... but this is not allowed in Open as the factory firewall must remain?? is that right??
but i cannot enter into Pro on my own accord as its invite only and spots are limited... is that right??
what can i do?? who can i talk to??
do i just do it and run some quick times at track days and hope for an invite??
pro just says no tube frame chassis or tube frame extensions on the chassis.... doesnt say
moving the engines around is allowed in japanese time attack..
i dont want a sports sedan category either... 15cm is hardly making it a sports sedan.. the original dash and everything will remain.. the firewall will just be sectioned back to the windscreen level..
if the original firewall must remain does that mean i cant section out bits to allow a pedal box to be mounted as far forward as possible??
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
