considering NS isn't a used as it once was. ill re-post my question here to get another angle and probably better responses.
So i finally have enough cash to start looking at the low end of the cars i would want, however still not sure what i should get, even after 9months on the forum. Currently looking into s14 series 1 (ADM models) or r32 skylines gts-t (the later years). a friend owns a near stock type x and the SRs pull well, decent amounts of down low torque while on the other hand, the rb20s have considerably less torque but more top end. considering the way i will be driving the car, its going to have to take a decent amount of limiter bashing (well, at least compared to other cars around the same price range)
while some will say, go drive both cars and find out which car you like better. well, the problem with that is, i still really cant drive a manual (cant learn if you dont own one, neither do my parents), not good enough to take one for a test drive thus have an automatic restriction on my license. i plan to buy the car, learn and resit the test and no, i dont have to worry about bs turbo restrictions. i have driven a friends r32 however, it wasnt very stock, had considerably more power then stock plus different turbo so different response.
what would you do? remember the car will be a daily and probably will see the track in the future plus, the hills.
Edited by Peter89
https://www.sau.com.au/forums/topic/296273-which-car/
i had a s13 and have been in a 32. i would go the s14 for sure. just get rid of the stock turbo and find a BB unit of a JDM s15 (i'm pretty sure they are a bigger turbo) and wind the boost up to 15psi and you will be laughing.
other suggestion i would make is a r33. they are cheaper than r32's and go much better. buttloads more torque, more power everywhere actually. and better as a daily driver than the 32 due to smoother power. performance wise a 33 with a few mods (such as boost at 12psi, and the usual mods such as exhaust and cooler) and a silvia at 15psi (with similar mods to the 33) will be pretty close, but both will be quicker than a 32 with the same mods. even with the stock turbo @ 15psi the s14 will still beat the r32
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4936976
33 isnt an option on his power/weight laws.
SR S13/180 isnt either.
I still say R32, the way you drive, SR will POP, RB20 wont as easily, and it wont spend enough time under 4k to notice the lack of low down, and the S13 you spend a lot of time in accentuates the boost transition compared to an S14 with the VCT(S13 noticable, S14 smooth) where an RB20 just smoothly revs out, which makes it feel like it has more down low than it does., that stock s14 was gutless, smooth but meh... catback to finish the exhaust and remap would change that though.
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4937016
Hey Peter!
I like both cars you mentioned,
As for a Daily, you'd figure the S14 would be better on fuel with less 2 cylinders... But your buying a performance car, no such thing as fuel economy.
The cars are quite easy to drive in stock form, once modified, its a different story.
For Track, Circuit or Drift? R32 would have more top end and I find the Silvia's are more tail happy for drift. They both can do the job, just depends on how you set the cars up.
In the mean time, learn to drive a manual, last thing is you want to stall it after giving the car full stick.
BTW your Roman's friend yeah..? I think I met ya at Campbellfield after the big Skyline cruise.
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4938855
The RB's cast iron block will take more abuse than the SR's alloy one. But the SR is a nicer motor if you're sticking to 2.0L and you're not going to hammer it all the time.
If its a daily and not a track-only car I'd get an SR powered vehicle. You won't be hammering it that hard on the street, hopefully, and that's where it will spend the majority of its time.
Go rent one. If you're going to burn out a clutch, burn out someone else's.
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4938884
he's burning out mine haha
my 32 is great on fuel.
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4939604
you would think that is a good option, however to rent a car, drive must be 25 and full licensed.
ill learn on the car i buy, spent the last 4 years driving, 2.5 years on P's. should be able to pick it up quickly with daily practice. which is the only thing stopping me currently.
Hey Peter!
yeh I am. still stuck as passenger for now however, i cant remember you. that was too long ago, i suck at names and you meet some many people in the car scene, my head hurts :D
i think ill focus more on grip racing in the future. currently leaning towards the skyline, i thrash my current car, considerably slower but yeh, doubt that ll change. with fuel efficiency, anything is better then what i currently drive.
Edited by Peter89
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4940059
i know r33s are good performance wise, however still on p plate thus illegal plus i would rather a smaller, lighter car. been driving a large car for long enough.
i wouldn't really class the r32 as being much lighter than a 33 as there is only about 40kg in it. and as for smaller, well there is only 3.5cm difference in width between a 32 coupe and a 33 coupe, and 11cm in length. and a s14 is actually 1cm wider than a 33. although they are lighter than both a 32 and 33.
also, when did you get your p's, because i was just looking at the vicroads website and if you got your p's after 1st july 2007 then you can rule out the s14 (unless you go a non-turbo) and just get a r32 4 door (r32 coupe also ruled out) as you can't drive a turbo vehicle with only 2 doors.
this is what i was reading:
Lower perfomance turbocharged or supercharged vehicles
From 6 July 2009, drivers issued with a probationary licence on or after 1 July 2007 may drive some lower performance turbocharged or supercharged vehicles. The definition of a lower performance turbocharged or supercharged vehicle is a vehicle with 6 cylinders or less that is;
* turbocharged or supercharged with a power to weight ratio of less than 100kW per tonne;
* turbocharged or supercharged with a power to weight ratio between 100kW and 125kW per tonne and that is considered to be a family type vehicle (4 seats or more) rather than a sports type vehicle. A family type vehicle is a sedan, station wagon or hatch normally used to carry families/passengers with 4 or more seats and are equipped with child restraint anchorages. A family type vehicle does not include a sports car (two door coupe).
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4940830
yeh I am. still stuck as passenger for now however, i cant remember you. that was too long ago, i suck at names and you meet some many people in the car scene, my head hurts :wave:
Up / down Hill Grip race ey... Sound good.
Give the AE86 and NS fellas a good run LOL!
Yeah I was the Asian guy driving the Grey R32 GTR and Josef was riding passenger in my car.
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4940905
Not entirely true. From the Hertz web site:
Drivers aged 21-24 years may be eligible to rent subject to an age surcharge. Age surcharge is $27.50 per day including GST (Airport Concession Recovery (ACFR) maybe added subject to rental location).
I believe that other companies have similar requirements. You can't rent a really fancy or sporty car unless you're 25, but to score a Corolla or the like can be done pretty early. They may require a full license though.
If you can drive, it shouldn't take too long to pick up.
If worst comes to worst, go to one of those Learner instructors and ask for one lesson in a manual. They'll teach you the basics, then its all just practice.
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4941285
mad082: turbo laws don't affect me. i made sure of that by rushing to get my auto license before the laws came into affect.
ill be on holidays for 3 months, with occasional work, so ill have plenty of time to learn. ill finally have a decent working aircon, will make summer driving more enjoyable.
leaning towards the r32s. going to inspect some this weekend. probably will inspect another s14 and a 180 before i decide.
Edited by Peter89
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4942028
If you havent decided, I'd have a think again bout the car you're leaning towards.
Just my personal preference though...the R32 GTS-T is starting to look a bit dated.
I'm well aware this is SAU so opinions will be biased but only the R32 GTR looks the part.
You can easily turn the S14 or 180 into a tough and more uptodate looking car with just the right body bits (eg: front lip for an old style 180).
Dont think there's much you can do for the look of an R32 GTS-T even with a body kit. IMO, that bonnet looks horrible.
So for your price range, I'd say:
1990-94 180sx
Lowered
Front lip (SR or CA front bar)
Tough wheels
Profit
:P
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4949976
styling doesn't really matter for me. the car itself is way more important.
the 180s you are talking about, have 4 stud, small brakes and red top SRs. inferior compared to a s1 s14.
however, still sold on r32s. just hard finding a clean one :P
https://www.sau.com.au/forums/topic/296273-which-car/#findComment-4950887
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
