Sushi Meet Availibility
38 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 67
Always a duck or sushi nite, what about chicken nite goddammit! :thumbsup:
we own asian cars, we like asian food. it makes sense. hehe. chickens so boring :D
I wish I enjoyed sushi :(
i dont really, the nori leaves a funny taste in my mouth and i find the smell a bit off putting. I prefer rice paper rolls - susshi filling wrapped in rice paper. All other asian food is also good...for the most part.
Red Rooster or KFC?
:D
I don't know how ppl do.....
Raw food :(
Raw fish is nice, but must be FRESH!
Besides sushi, there is cooked food as well, like beef, chicken, seafood and vegetables.
LOL, not everything there is RAW :thumbsup: They do have other COOKED dishes, even with rice :D
Also, once we've got a date, I'll go up to the restaurant and get a copy of their menu and ill type it up for everyone, so for those who doesn't eat raw things, can have a look at the cooked stuff :(
And yeah, I was just thinking that 3rd week might be a little too close to xmas, so I think if the meet happens to be late in the week, we'll have the in the 2nd week of Dec?
KFC isn't chicken?! :thumbsup:
Anyway I just voted but most likely won't be able to make it haha.
But who knows!
There's always a person that's gotta ruin everything for everyone haha :D
Now the votes are rigged! :(
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
