  • 2 months later...
  • Replies 52
To keep it simple, if you need your belts changed, and you are in Melb:
1. Call Chris at City Nissan and ask for the belts to be changed 03 8383 8822
I did my belts today and got spare change from $200....I was shocked by how 'cheap' the job was...I was think more like $280 or something...
Why go for aftermarket when you can go for OEM? I feel so much easier now, after having replaced the belts...
Hi All,
I have the 300GT and my belts + labour was $160 + GST from the local Ultra tune. Not sure if its different for the 350GT.
Had to get it done because a bolt from the engine block had somehow worked its way free and started eating through the main belt. It had 2 teeth remaining when I noticed, would have thrown it a couple of days later..
Cheers
Lee
Hi All,
According to FAST and Parts Master, the two belts (AY140-61175 and AY14N-4094E) are used on the following engines;
VQ25dd
VQ25det
VQ30dd
VQ30det
VQ35de
  • 1 year later...
hey guys didnt want to start a new thread, but i need some belts again, this time for a 2004 (series 2) v35 sedan 250gt - the part number is mentioned but no one has mentioned the actual size for the 250gt sedan, any help?
  • 4 years later...
Sorry to dig up a old thread. Today i purchased belts that have a completely different part number from Gates via Repco. They are the Micro-V.
4PK775 6PK1080. They suit Nissan Maxima 3.5 VQ35DE. My car is a late 2005 coupe. I can't see why they will not fit. Its the same engine or am i missing something?????
yeah, just because they are the same engine, doesn't mean all the accessories (alternator/power steering pump, aircon compressor, tensioners), are all in the same positions, these items get moved around to suit the engine layout, and therefore use different sized belts.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
