Yep, it happened on Friday. A Grade 4.5 96 R33 GTR V-spec came up at a Japan auction, had the VIN checked out to ensure it is a genuine V-spec, and now it is mine. Now I just have to wait for its arrival. The next available ship leaves Japan on the 16th of January and arrive at Brisbane on the 28th of January. So if everything goes to plan I should be driving it buy early-mid Feb!!!!! How hard is the wait going the be! Can't wait! I only have the auction pics at the moment but should have more sent to me by the end of the week. It is stock, bar the exhaust. I really wanted a 97+ GTR to get the Xenon lights and other upgrades but this one was too good to pass up.
https://www.sau.com.au/forums/topic/29763-i-have-offically-joined-the-gtr-club/
  • Replies 108
Thanks guys, I definately know what its like to be waiting by the phone waiting for 'that' call, and the wait is already killing me!
I ended up going through Direct Imported Auto Brokers, otherwise known as 'PRIMO' on these forums. He was real easy to deal with.
Out of curiousity how do you plan to comply this car??
There are a few workshops are ready to do 33s under RAWs at the moment, early next year there should be some doing 32s and 34s. I can't remeber the name of the workshop at the moment but it is down the Gold Coast.
Final cost should be around $45k possibly a little more. The new scheme is definately not as cheap as the old one, but should keep quality and maybe resale up (fingers crossed). Grade 4 V-specs are around $44-50, non V-specs about $40k+. You can go cheaper with lower grades but then you run a compliance risk with the tuffness of RAWs.
Probably could have got one cheaper locally but after looking for the past 4 months the choice wasn't out there, especially for genuine v-specs. Alot of rough examples.
looks great...with the Xenon lights you can usally find them at some importers.
I will look into that, xenons would be nice. I will also try and get the series 3 lower lip, they look more aggressive.
Guest darrinspencer
It really sucks having to wait
When i imported my car it seemed to take ages, but it is worth the wait
Do you or have you have been told if you have to change the exhaust back to standard?
If you have to put a standard one on for compliance, do you get to keep the old one?
I was told by the company that complied my car it has to be distroyed once removed. you do not get to keep it
The new rules are really tuff
Even window tint has to be removed.
Cheers Guys!
Checked with the compliance workshop and they said they have a standard one they will fit for compliance then just put the other one back on. There is no way they will be destroying it, even if I have to take it off as it comes off the ship!
Guest darrinspencer
That's great if they let you keep it.
there seems to be alot of mixed up stories going around regarding the new rules.
I suppose it is up to each compliance workshop whether they want to risk loosing their licence.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
