  • 2 months later...
  • Replies 46
  • 2 months later...
i owned one of these new gen. alphard back in jakarta. 6 pilot-config seats perfect for young families, IMO add 10% tint, dished jap rims, personal driver and its gonna be a massive head-turner everytime u stepped out of the car in australia (VVIP).
problem: every freaking things (HU, sensors, wiring, MFD) are in japs language. even when u're opening the rolling door & tailgating / standing near to something, a middle-aged lady will give u an announcement in japs. annoying if ure driving in big cities where ppl walks near to your car.
good things: pretty good launch for a big 4wd baboon (3.5L engine), it beats my e-class merc in terms of comfy. perfect for long-range driving.
best next weapon of choice if u own R34 gtr and ur gf got pregnant for twins or triplets. lol
  • 2 months later...
Saw an Alphard in Chatswood, NSW (Sydney). Black with black plates, with some Junction Produce (or that HK imitation) stuff on it. Still love the Elgrand E51, but the Alphard is pretty cool too.
1MZ-FE with TRD supercharger (US Toyota made), Boost = 10.00psi, Power = 343bhp and torque = 373 Nm at 4400rpm. Not great, but guess it'll feel like a limousine.
how much is the El Grand currently?
we bought an e51 about a year ago for about 800000yen from a dealer. so there probably still around that figure or a little bit less depending on trim level..
there big, i fit my 8foot surboard in the back without it coming into the drivers area at all
The fact that I want one for a family bus has nothing to do with it of course.
Kristian... have you heard of contraception? most people stop making offspring after #3.
yeaaah you're totally right - i mean i know when i thrash the tits off my dad's kia carnival i can't help but wish it was RWD so i could rip fat dardy skids in it
(that was sarcasm)
i don't think toyota wanted the alphard to make big power mods or to be raced man!
they're in a special category of vehicles that's designed to move people ;):P
(that was sarcasm)
that's totally why buses are FWD right? (that too was sarcasm)
he's right, most things that are designed to carry heavy loads or pull heavy loads are RWD so that the wheels don't bog down like a dog dragging its arse on the floor. Most of the FWD models switch to AWD when there's too much load or slip on the front. Only poverty model vans come in FWD... like a Kia Carnival :(
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
