My 250gtm is overheating .. .help.
this is what happens.
when driving with load on the engine (e.g air con on or going up long hills) , the temp get up to about 3/4 way. Normally sits at around just below 1/2 way. Under normal driving without the air con on and flat motoway / city driving it stays at normal temp. You can sit on idle without overheating.
Doesn't seem to be related to the air con as I can replicate the overheating by driving around with the brakes slightly on to simulate load.
I've had the car 2 years.
Engines done 55K and been serviced regularly
It just had a full service a few weeks before the problem occured. New oil and oil filter and air filter etc.
Didn't touch the cooling system. Oil is the same thats been used for last two years - magnatec and level is good.
I flushed coolant after the over heating problem occurred.
My wife got it so hot going up hill with 5 ppl in the car that the coolant overheated started to pour out steam from the top of the expansion/reserviour tank.
checked all the fuses and coolant pipes. no leaks.
this 250gt has no additional radiator fan part from the main one attached to the engine.
what could it be ?
Edited by Fanta R33GTR
https://www.sau.com.au/forums/topic/299830-help-v35-250gt-overheating-big-time/
I think its unlikely its the thermostat, because the only 2 faulty conditions it could have are either stuck open or stuck closed. If it was stuck closed, then you wouldn't get boiling coolant steaming out of the overflow tank, as it only gets coolant from the radiator. If it was stuck open, then it definitely wouldn't overheat.
Could also of course be the thermo fan, but I wouldn't have thought it would be an issue if you are driving, as that usually has enough airflow to cool without the fan.
I'm leaning more towards a water pump issue, either way, take it to a mechanic asap, then let us know if I got it right :rofl:
Edited by GoldV35
I would be taking it to the mechanic that services ur car asap. Might be a faulty thermostat. have u checked ur radiator fan is coming on?
this car has no additional fans. Only the one big one attached to the engine. I know some cars also have another one on front of the air con radiator, but this car only has the one.
I'm leaning more towards a water pump issue, either way, take it to a mechanic asap, then let us know if I got it right :)
is there a easy way to test if to see if it is the pump at fault ?
From a cold start (so you don't get hot coolant blowing up in your face), take the radiator cap off and check if you can see the water flowing. Gradually accelerate and the water flow should increase with it. Check for any water dripping from the engine which would indicate any leaks from the water pump itself or possibly a blown welsh plug.
If your radiator fan isn't working, your car will overheat at idle after about 5 - 10 min and you'll know about it.
Worst case scenario, could be a blown head gasket. Happened in my old Maxima like that once.
its probably easier to check/change the thermostat than stuff around with the water pump. which will probably whine if its a problem
if your thermostat was stuck closed, it CAN spit out the overflow tank as the pressure build up forces the coolant out anywhere it can
but before doing this, dump all the coolant out, and refill the system and bleed it properly! there will be a bleed point on one of the flanges. it could be you just have some air stuck in the system. turn on the heater (on full) and run it like that for a while too.
yeah...... it has a 3 year warranty from the dealer, so I dropped it into them and will let them sort it out. Not much i can do.
Thanks
  • 10 months later...
Thanks
Is it fixed yet? and if so what was the problem please?
  • 3 years later...
The cooling system probably needs to be bled correctly, it is quite difficult to get all the air out. There are a few threads on the subject, here and in the Stagea section for M35's
If it continues or reoccurs, perhaps there isn't enough anti boil coolant in the system, and the water is flash boiling in the head and around the bore. (these run 95-100 degrees on a cold day) Drain and fill with the recommended coolant percentages and re-bleed a few times once it's cold through the rear bleed point only. Obviously you would be checking the thermostats operation while the coolant is dropped, by testing it in a pot of water on the boil, and replacing the radiator cap, just in case.
If you still have issues, you could have a blown head gasket... I have seen it a few times. :/
  • 4 years later...
I just recently changed my high pressure pump and this problem started a week ago when it blew a hole on the top tank of the radiator. The engine runs for 5 minutes then coolant starts coming back as the water pressure builds up. It even cracked my radiator and was sparing the water from there. I just changed the radiator because of that.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
