I drive a built 32 gtr with a T04z on the circuit and i dont think the car will be any fun at all with a 7k redline. Honestly your power ban and redline will come together like cousins at a tasmanian family reunion!
You need to be able to rev it til at least 8000-8500 to really make it somewhat responsive!
HAHAHA Yeh well true. Is your 32 gtr a 26 or 26/30? What is your redline? What rear housing do you have on the turbo?
  • Replies 42
Posted Images
Its just a forged 26, The 32 is my best mates and was only recently acquired from another
friend who invested the big dollars into the car. I shift at about 8k on the circuit [which is hard in the lower gears], im not sure what the redline cutout is. I have seen the car spin nearly 9k without the revlimiter cut-out so i imagine it is @9k. from memory the rear housing is .84. not 100% though
will find out.
It might be a completely different application to yours, but i think that 7k will still prove to be too low in the lower gears.
These are just my thoughts for what they're worth .
A good friend used to tell me that a given result was "adequate" , and there doesn't necessarily have to be a number on it .
At a guess a street driven Skyline doesn't need 420 Kw to feel good and be more than adequate .
Trying to be realistic I think something in the 260-300 RwKw area is good performance provided it pulls reasonably and has a wide useful rev range .
I think aiming for a number like 420 Kw means the state of tune would have to be high even with three liters and maybe not so nice when driven like a std street car around the burbs .
Twin scroll single turbos can be great things but the munjaras to get everything working just so is a big stack of notes . Most people want an Rb30 bottom end to have more torque off boost and to spin bigish dryers up reasonably easily .
I would not be a great fan of GT3582R's but they have their place and some like them on RB30 twin cam engines . There obviously comes a time when the std manifold becomes a limitation and if it didn't the "t3" sized flange would .
Really the T04Z's need a turbine housing with the larger T4 International sized mounting flange because they have larger inlet passages as would an exhaust manifold with that sized flange . HKS uses the T4 sized flange and arguably their housings work better than Garretts Diesel spec ones on that cartridge - for a petrol application .
For me I'd use a GT3076R with the largest 1.06 A/R wastegated turbine housing on a steet car , wouldn't get 460 Kw but with a bit of engine work and the right CR I think 320 is achievable . Most won't go with that 1.06 housing because they think it makes GT3582R's feel laggy , why I don't know because it wouldn't have the GT35 turbine or GT40 compressor and as a plus a GT30 turbine housing is a match for a GT30 turbine . Different story with a GT35 turbine in a bored out GT30 turbine housing - maps show why .
Big turbine housings usually don't have creep issues because the gas speed is lower so more likely to take the exit stage left turn out throught the gate when it opens .
Just my two street cents spent , cheers A .
will find out.
AH ok yeh 26 are fine for rev's compared to the 30. Yeh if you could please find out that would be lovely.
Disco - I had a 3076r 0.82 for the car when it was to be a 25 but changed up to the 3582r 0.82 when i decided it would be a 25/30. Thought the 3076r would be a little too small and too lightswitch for the 30. I was told the 3582 on a 30 would be like a 3076 on a 25. Hoping so anyways. How would you rate the difference in spool time, etc etc (mainly everything you personally can think of) between the T3 1.06 gt35r and the T4 0.84 TS t04z
Well the whole idea of the 1.06 A/R turbine housing is to raise the boost threshold so it wouldn't be "too snappy" .
One of the things that makes Garrett's GT30 and GT35 turbines laggy in some peoples opinions is the big trim size - 84T . The point I'm making is that going big in A/R with a big trim turbine makes a big difference in gas speed through the housing . Usually when this topic is discussed I suggest people look at the turbine map for the GT30 turbine . The difference in the gas flow lines on Garretts graph is vast , greater than the difference between their 0.63 and 0.82 A/R GT30 housings . I also suggest they look at the GT3582R's turbine map and note the gentle curve towards the right for all three A/R housings with that GT35 turbine .
The only T series turbo , T04Z is a BB T series unit , I knew about on a SOHC RB30ET was a bush bearing T04S which had a 1.00 A/R turbine housaing and P trim T04 turbine . From memory the compressor was a T04 60-1 in a 0.70 A/R comp housing and the report was that it tore up the tarmack on 10 lbs of boost .
IMO is is an urban myth that mid sized twin scroll turbine housings improve "spool" . Twin scroll systems are not about gas speed they are about reducing manifold pressure and taking advantage of the pulse energy available .
A .
A .
Yeh well that makes me think a little differently now I guess. If there is minimal difference noticeable in twin scroll then meh. From what I was reading is it was wonderful :3some: Im still yet to see what my 3582 with 0.82 rear maxes out on. Cheers for the wise words :/
You're right I should pull out the motor and rebuild it all again? Is it so bad that I don't want to rev the f**k out of the motor? It is all balanced etc I just don't really want to rev the f**k out of it. Ive never even seen the rev limit in my car EVER. I will see how the car goes rev wise with this tune. Maybe I will put the limit at 7500. I was just thinking 7000 as I don't want to have to wait so god damn long if I had to rebuild again. I just kind of wanted this motor to last longer than 4 weeks. A build takes quite a while being a pov ass uni student. Is the extra 500rpm that big of a difference? It only a street car. It has never seen a race track or a drag strip ever.
Haha, don't get me wrong, i only own a Suzuki serrai, I don't think i've even ever touched a skyline. However, logically, you can pretty easily determine that if your engine goes, its either going to be because of some catastrophic failure (eg, oil pump), or from general wear. Ask the guy who built the engine how high it should be reved, get a good oil pump if your worried about that shitting itself, and set your rev limit accordingly. Remember, redline at 7000 or 8000rpm isn't going to be a huge difference in wear, especially if its not a full time track care and will be seeing a lot of time putting around the suburbs at 3000rpm anyway.
Yeh I think Im not going to touch the 8000rpm limit. putting around the burbs haha just sounds so silly. Yeh well I dont want to risk oil pump failure. Maybe if the engine does a naughty broken thing I will just put in the better oil pump that time. Yeh like JonnoHR31 said I thought there was a fairly big difference between stress from 7000 to 8000.
I just never thought it was common practise to take the twin cam 30 to 8k. I will definately update this thread depending on what tuner says etc etc and how my 35r 0.82 goes on the 25/30 :cheers: Which reminds me it is once again time to phone the mechanics to see what they have to say with progress etc
Edited by Lukas 33
the RB30 engine has no issues with revs
my 30 is currently limited to 7500rpm as i only have the stock ballancer
AL's 30 is limited to 8000rpm with an aftermarket ballancer
both engines are forged and all the internals well balanced.
or there is the rips engine massive power and stock internals (with some prep work) and occasionally hits 10000rpm
Yeh my internals are balanced but only has a stock balancer. You have to admit rob is an exception when it comes to rb30. Just because he can rev to 10000rpm and hit 1000hp doesn't mean I have a chance in hell haha
Good balancing and a good balancer, there is no reason why you can't spin the 30 to 9k.
My mates 30 has the rev limit at 8k and I'll probably set mine the same unless power drops off earlier.
Even without a good oil pump?
For information sake, my seat of the pants o meter seems to think there isnt really a huge deal between the .82 and 1.06 housing lag wise on a rb30/25.
I changed from the .82 to the 1.06 housing and while boost didnt spool as early, it was annoying undrivable. I actually prefer the fact it kicks in a bit more.
I would love to give you some comparible dyno numbers but unfortunately my engine lost all oil pressure while i was getting the 1.06 turbo tuned. When its fixed, ill post up some comparisons
Edited by SirRacer
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
