  • Replies 3.6k
Posted Images
Not a fan of the MP4-25's engine cover but I do like the new wheels and of course the rear diffuser :P
The new Ferrari is like..... a Ferrari and I like the new wheels. The new Renault looks like one of Eddie's old B&H Jordans and the new Sauber looks very nice with it's simplistic colour scheme and again I'm a fan of the wheels.
I was thinking the same when I saw it. If it wasn't for the dabs of red front and rear, it'd do a good imitation.
Renault's all over the show with their colour-schemes in recent years. They seem to want revolution rather than gradual evolution.
Looking at all the different nose-cone shots above, the MP4-25 has an insane amount of different aerofoil elements and twists'n'turns going on in theirs compared to the others. The computer that did the CFD modeling must still be smouldering,
Timing from last nights test. Interesting top 3!
Pos Driver Team Time Laps
1. Massa Ferrari (B) 1:12.574 102
2. de la Rosa BMW Sauber-Ferrari (B) 1:12.784 74
3. M.Schumacher Mercedes GP (B) 1:12.947 40
4. Rosberg Mercedes GP (B) 1:13.543 39
5. Paffett McLaren-Mercedes (B) 1:13.846 86
6. Barrichello Williams-Cosworth (B) 1:14.449 75
7. Buemi Toro Rosso-Ferrari (B) 1:14.762 18
8. Kubica Renault (B) 1:15.000 69
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
