  • Replies 3.6k
Posted Images
Had a look at it and it's the long awaited F1 2010 by codemasters, looks fkn brilliant but if I read the article correctly we won't see it until the Singapore GP!!!! I'm on F1 Championship Edition and love it and that's nearly 4 years old
the guy with a whole 2 wins in 8 seasons says the cars are too easy to drive. right
if it's so easy Mr Jawbone, how come you're best known for tripping over your own feet when there's no other cars around?
Apparently F1 are sissies these days according to captain chin!
http://www.crash.net/f1/comments/157583/1/...ues_webber.html
LOL. reading crash, the worst website ever. Interested to know what the context and full comments were. But i agree...the cars are slower then years past, have more tyre grip, less cornering speed from less aero, with less hp, safer, more reliable. Montoya took off how many races when he tripped on a frigging tennis ball!
They are a bunch of sooks!
yeah I agree with what webber said too. 10 years ago you would not have seen these little pre-pubescent hacks in there up in the mid pack (or better!). they would have been lucky to make the 110% rule... what he said was pretty fair about the new hack teams and drivers. got to love webber. he is certainly not out there to win a popularity contest. his little defence of flava flav at the end ensures that!!
lay of the chin man. he's a good egg!
what's the 110% rule?
you know the old rule about all cars had to qualify within 110% of the fastest qualifying time to make the grid. something like that. I don't think it's still in play. it could be though?!?
Unless I'm mistaken Richard, wasn't that the 107% rule? Not 110%...
Either which way I agree with Webbers statements too, it goes for most sportsmen in general...
1989 grand final, when Dipper and Dermy both played on with a punctured lung and bruised liver respectively, both with internal bleeding and both winding up in hospital post game.... Now look at the pansyfl.... All full of do-gooders and soft-cocks...Everyone may as well give up and play soccer and badminton.. Motorsport has definitely gone the same way..
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
