  • Replies 3.6k
Posted Images
Had a look at it and it's the long awaited F1 2010 by codemasters, looks fkn brilliant but if I read the article correctly we won't see it until the Singapore GP!!!! I'm on F1 Championship Edition and love it and that's nearly 4 years old
the guy with a whole 2 wins in 8 seasons says the cars are too easy to drive. right
if it's so easy Mr Jawbone, how come you're best known for tripping over your own feet when there's no other cars around?
Apparently F1 are sissies these days according to captain chin!
http://www.crash.net/f1/comments/157583/1/...ues_webber.html
LOL. reading crash, the worst website ever. Interested to know what the context and full comments were. But i agree...the cars are slower then years past, have more tyre grip, less cornering speed from less aero, with less hp, safer, more reliable. Montoya took off how many races when he tripped on a frigging tennis ball!
They are a bunch of sooks!
yeah I agree with what webber said too. 10 years ago you would not have seen these little pre-pubescent hacks in there up in the mid pack (or better!). they would have been lucky to make the 110% rule... what he said was pretty fair about the new hack teams and drivers. got to love webber. he is certainly not out there to win a popularity contest. his little defence of flava flav at the end ensures that!!
lay of the chin man. he's a good egg!
what's the 110% rule?
you know the old rule about all cars had to qualify within 110% of the fastest qualifying time to make the grid. something like that. I don't think it's still in play. it could be though?!?
Unless I'm mistaken Richard, wasn't that the 107% rule? Not 110%...
Either which way I agree with Webbers statements too, it goes for most sportsmen in general...
1989 grand final, when Dipper and Dermy both played on with a punctured lung and bruised liver respectively, both with internal bleeding and both winding up in hospital post game.... Now look at the pansyfl.... All full of do-gooders and soft-cocks...Everyone may as well give up and play soccer and badminton.. Motorsport has definitely gone the same way..
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
