I know I would rather be driving a car that was quick over one lap and then preserve my tyres by driving sensibly than having a slow car and trying to wring the neck of it to keep up.
RBR and Ferrari in a very good position for the race.
Still though, there is only so much that driving technique and throttle-brake control can affect tyre wear... Ultimately, if it ends up being a scorcher tomorrow, they could tickle those slicks and still have them grain and wear badly.. Were as the hard will be more durable..
  • Replies 3.6k
Posted Images
we'll see... personally, I'd rather have the better handling car for the majority of the race than just be able to do 1 fast lap on empty tanks. 150kg of fuel has to alter the car's behaviour.
Alonso in the fezza is pretty exciting. The team mate battles in Ferrari, McLaren & RBR are going to be interesting. And see how the self-confessed rusty old man goes. Qualifying 7th and only a couple of tenths off the young gun teammate is not bad for his first competitive drive in 3 years if you ask me.
I can't wait for the race!
I agree but I'm not sure those two things are necessarily mutually exclusive. We don't know which cars are easy on tyres yet but it won't be long till we find out.
It still reckon it easier to make a fast car go slow than try to make a slow car go fast.
not the hand-me-down win he was looking for, but alonso looked wrapped to be back
showing the schmucks how its done, im glad he a contender again. would have been sad to see the best guy on the grid running around in 12th for another year
EDIT:
lol
old dead eye doenst look too happy with 2nd
... get used to it buddy
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
