  • Replies 3.6k
Posted Images
Hey guys. I missed the race, know the result. How can i get a copy of the footage? Tried a number of torrents without success
Cheers
I have nearly all the races for the last six years on tape so if you PM me your address I can send you a DVD.
Gents,
Who is in for a trip to Singapore?
Names and Availability to me ASAP!
i'll be there, finally got some time off work so doing 2 weeks with the GP in the middle. i went with the 3 day premium walkabout, around $360aus i think.
in other news though, Helmut Marko the irrelevant old fool has opened his mouth again...
http://planetf1.com/news/3213/6262987/-Vet...ing-Conspiracy-
i cant quite get his measure, now he couldnt be that dumb.... read what he says, he seriously has no idea.
Just read this this morning - :down: What an absolute dropkick. Where would Webber be without Redbull? How about where the f*ck would Rebull be without Webber? Where do you reckon Red Bull got all their driver feedback from?
Does this man have anything useful to contribute?
hehe, just as all hope is lost i get an email saying my start date would be on 1 September in Brussels. I may make Spa yet :) Just need to agree on terms of the contract. People complain about owning a modified car here in Aus. Has anyone ever looked at registration /car ownership costs n Belgium. Talk about anti performance car....they tax you through the ass on anything over 120hp :P
Some good quotes from SebVet on crash.net:
“The team is the priority,” the 23-year-old told German magazine Der Spiegel now that another truce has been re-established, “[but] in the end the pecking order is led by the faster man. Every driver is an egotist, because you go down in F1 if you aren't. The team-mate is the first you want to beat because he has the same equipment.
“There is always a certain distance [between himself and Webber]. We work together in certain areas to bring the team forward and to further develop the car, but apart from that everyone is focussed on himself and seeks his own advantage. I have no joy in being an also-ran. I need this self-affirmation that I am better than the others.”
Surprisingly honest. They must have edited out the bitching and whining.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
