  • Replies 3.6k
Posted Images
Fgk commercials, lol you just knew when 10 takes a c'break that they would all freekn pit@@!
vetel just seems like a faster driver, <3 webz as an aussie in f1.
really enjoyed the team turning down the power on vetel's car to let webz through!
1HD always know the best time to take commercials. Its either when everyone goes to pit or we miss an important radio msg
It was worth at least 2 tenths by driving over the kerbs at the chicane plus the time it saved him returning to the correct line with the loss of drive.
Bigger speed humps is definitely an option, you shouldn't come out the other side ahead.
What were the stewards waiting for? Three trips (that was televised) across the chicane under pressure, the last being blatant, two covering moves to avoid being overtaken when compromised on the exit.
I need a job as a race steward, I would set up in the pool at Valencia to enjoy the view and hopefully the race wouldn't get in the way of having a good time.
just sad your lover boy didn't finish the race :banana:
Yeah he does have a knack of making these things interesting, but beyond that? Not a whole lot of happenings this weekend. Just 53 laps of no overtaking moves at the sharp end
If i attended this race instead of the sphincter of the universe i would have been dirty.
Hopefully Singapore brings some of the action back
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
