  • Replies 3.6k
Posted Images
lol who'd have thought the highlight of the evening was going to be a car on fire? Albert Park should lose the race to Noble park or somewhere in the western suburbs. what a show that'd be!!
Anyway, excellent drive by nando and vettel, shame redbull wasted another win. Got to put an end to that Christian
Next season should be very interesting if Kubica stays at Renault.. He's an epic driver love watching him.. With Kimi showing interest in the other Renault seat it seems apparent they should be on the up next year.
Those last few laps had my heart racing! Really thought Vettel was going to try a lunge!
agreed, some great passing in the middle of the pack. Kubica around the outside was pass of the race.
whats the go with the macs? seem very fragile......to think last race hamo hit the ferrari the same way contact was made on him and both times the mac has broken.....very frustrating for lewis. what was the go with slower cars being in the train on the restart? that was possibly the reason mark & lewis came together in the first place.
im glad there was some racing in the middle, made it enjoyable.
Kubica did a great job...bit i was equally impressed with how Webber got on with it and was overtaking cars on the quicker tyres. I was impressed hpw he cut some nice moves on Glock, Kobayashi & Schuey
Webber's been very lucky twice now. First in T urkey with Vetool then Hamo last night, both could have been DNFs but he's finished third instead on both occasions
Anyone want to explain why T urkey was replaced with "the sphincter of the universe"
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
