  • Replies 3.6k
Posted Images
why is daryl beattie yelling at us
him and greg rust they forget there's a microphone in front of them, don't have to yell. f**kwits.
apparently i was sitting near greg rust coming back from melbourne one year. lucky my mate only told me after we got off the plane i would have punched rust in the head if i'd known.
shit
4 months till 2011
what the hell do people do if your not looking ahead to this every fortnight
i'll be thanking various deitys that i don't have to see another ashley and f**kin martin hair loss ad until march.
GUTTED! How Fezz lost it? Webber rolled the dice and at least he had a go. Vettel has been clearly the quikcest guy out there the last few months and the back half of the season shows he deserved it. But real shame for Mark who did it all season...to lose it in such a touch, close fight :)
And young Jessica, no wonder Button doesnt give a shit if he is quick or not!
Well Webber certainly had his chances to pass Alonso when Alonso ran wide, what was it, 2 or 3 times? But he just wasn't close enough.
All I can say is, at least Alonso didn't win :) I was sure he was a shoe-in before the race.
Almost forgot to mention Schumacher's near-decapitation... :D just half a metre to the left and...
Edited by acediac
Am I the only one that heard beatie call vettel vetool at the end? Wastge only positive I took from that race
As for button's mrs, she's alright but I wouldn't rate her as highly as you guys seem to be. I've been with better looking women and I'm no millionaire F1 driver
I have this kind of empty feeling after last nights race. Ultimately I didn't want Vettel to win it, but the back half of the season he was blindingly quick, and to get 10 poles in a season and not win the WDC there must be something wrong. As much as I class him as the villian, he did deserve it. As for Webber, I thought he did great all season, particularly being able to not only match his team mate, but beat him half the time, as well as the Ferrari's and McLaren's. I can guarantee that he will get a shit-canning in the Australian media this week, with people beating him up over his mistake in Korea, his flight in Valencia etc., but fact to the matter is, every driver makes 2 or 3 mistakes during a season, yet Mark was just totally unlucky in the end.
and hows these cunts form
I swear to the all mighty allah, i heard "alonso predicted he would win the title... blah blah blah" at least 3 or 4 times every race for the last 4 races. They were obsessed by it. And now? Not a word form Beattie and that dipshit Baird. No mention that it may not have worked out for him like he predicted
I think i just cant stand craig baird
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
