Guy's Cruise Control Stuck On 80 Km/h
  • Replies 53
Cruise control is designed to maintain speed. If you go up a hill it accelerates to keep the speed. So if you apply the brakes and cruise control is stuck on it will simply open the throttle more. Engines are more powerful than brakes so that part makes sense.
Actually my old Ford '96 model, when you brake cruise control is de-activated automatically, you can accelerate but braking manually causes cruise control to back down....
Did some quick research, the newer Ford's often have issues with this deactivation mechanism.
The other thing that would be interesting, the Ford's usually have On/Off and +/- on cruise control, could he have slowed down the cruise control until it stopped accelerating?
That and the drop it into neutral....but I thought police would have suggested that anyway...
+1 for just putting it into neutral...
He could have just shifted it in and the car would have rolled to a stop?
Unless im missing something?
sounds a little sus to me - maybe he is trying a stunt like that family in the states balloon boy all over again!!!
I'd say it was an auto, otherwise you just put your foot on the clutch.
These days most auto levers aren't mechanically connected to the box, only electrically, so if the computer didn't think it was a good idea to move to neutral it probably wouldn't.
I'm not even sure ignition keys actually form a circuit with the starter anymore?
Maybe they should test this guy for smoking pot that morning or something
LOL
Ford Exploder I believe the dealerships refer to them as.
ROFL
Gone are the days when you could just remove the centre pin from your horse saddle and let the wagon roll to a stop just shy of a cliff edge.
You sound like you're old enough to remember that :)
Hey, what would happen if you managed to put it into neutral with a stuck cruise control? Would it still rev the shit out of that engine?
Would this be a different situation on manual cars with cruise control? As these systems can't change gears for you like the auto ones can?
Just trying to figure out what the best thing to do if we found ourselves in that situation is. So I guess it should be (trying one after the other):
1. Try braking
2. Turn key to "acc" position as Ash suggested - engine off but no steering wheel lock
3. Try to decelerate on the cruise control setting +/- setting
4. Put car in neutral
if you turn the key off, and then just back to accessories, the car should not still be running - and without a wheel lock :)
Yes, but when going to "off" the wheel could still temporarily lock... it is still a far more dangerous option than neutral. Plus when you go back to "Acc" you still have no power steering which in heavy cars can make steering seriously difficult.
That is not unique to your car. Every car fitted with cruise control when you brake it should automatically disengage cruise control.... This obviously was not happening for this guy.
1. Try braking
If turning cruise off doesn't work, and a quick touch of the brakes doesn't disengage it either then always always go to neutral... if the throttle became stuck open which has happened to some people also, again go to neutral... Then stop the car and turn it off.
Traveling in a moving car and turning the engine off is HIGHLY unwise.
I decided to quickly try this in a VX Commodore, cruise control set to 60km/h, shifted to neutral, instant redline LOL :)
The car did slow down however.. and I didn't find myself on the wrong side of the road in Frankston.
at 80km/h power steering does fk all...
i spoke to an ex ford mechanic, tapping brakes wouldn't of stopped the cruise control is this situation, couldn't of put that model auto in neutral, but he could of decreased the speed of the cruise control then stomped on the brake and applied the handbrake...
http://www.theage.com.au/national/cruise-c...91215-ktxn.html
Holy crap! Did anyone see this? Surely a massive Ford Explorer doing 80 km/h down the wrong side of the road while tooting its horn, with a police escort, would have been quite a sight. Apparently a "known" problem on Ford Explorers :) !!!!
Why the hell would anyone spend all that extra money to import a second-rate American SUV is beyond me. I have rellies and friends in the US, and none of them own US made vehicles as they are generally so crap/unreliable, not to mention potentially lethal!
Jap for me please.
I smell some attention seeking kid. Don't believe that his cruise got stuck...
My "theory" - He probably got busted speeding or doing something illegal and to cover it up faking his cruise control screwing up.... as a bonus he would make the evening news, and how would you get whiplash from hard braking....
Sounds way too sus....
Just a thought - assuming his car was NOT drive-by-wire.
1. Try to lift the throttle from behind, if that fails...
2. Give the throttle, a fast hard jab to break the cruise control/throttle linkage.
I think he's chasing money...
Doesn't add up.
My mums EL falcon goes through brake switch's every 2-3 years. Just after 12 warranty on the part. Takes 5 mins to replace and the first time I notice it is when cruise doesn't disengage however it still turns off if you brake hard enough. I often see EF-EL fords with no brake lights for the same reason.
what makes you say that? i was always lead to believe even average breaks on a povopack commodore were the equivelant of like 400+rwkw.
i've never tried it at speed, let alone in a ford explorer, but if u just mashed both brake and accelerator at once, wouldnt the car slow? i've been in a few shitboxes trying to do skids and got it going at a slow speed then mashed both pedals (weight transfer helps get the rears spinning haha) and most times if they dont start spinning the car will just stop. obviously there is more work in slowing a heavy car at speed, but theres also alot less torque acting on the wheels.
am i the only one who would try and scando flick it and throw it into a hoop? just to do skids on a packed freeway as much as stop the car :)
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
