Spotted some fat fella a coupla nights ago in a red R34 Nur-Spec GTR,being towed by what looked like half a dozen HKS TD88-34D turbines in harnesses(might've been Motec wiring looms...).Gave him a wave;could be mistaken,but I thought he called me a Ho,or something similar.Benefit of the doubt was given,as he looked really familiar...Couldn't spot a SAU sticker,but I think he was one of our crew...'cept the numberplates were a bit weird:XMA-501?
https://www.sau.com.au/forums/topic/30059-spotted/page/105/#findComment-1136485
Hey guys, Spotted a Gunmetal Grey GTR R32 heading out of Condor ridge (NSW plates). It's the third time in as many days. The guy driving just doesnt want to know about other Lines or drivers by the looks of things. Oh well his choice but just so damn unfreindly. Hope it's no one who visits this site - I feel it's rude, manners please!. Might waste him next time so he takes notice.
https://www.sau.com.au/forums/topic/30059-spotted/page/105/#findComment-1137476
Spotted a few skylines tonight out at the woden cinema's, and also a nice white chaser tourer V. drove all the way into civic with him. i'm fairly certain he frequents these forums. that's a bloody nice car you've got there, i'm glad you kicked my butt at the lights
https://www.sau.com.au/forums/topic/30059-spotted/page/105/#findComment-1137577
Meant to post earlier:spotted Sinista growling merrily along on Xmas night up Lanyon Drive from Hume as we went to look at all the pretty lights in E's ScoobyRoo.Damn,the 32 sounds horn...and it has such a presence,you can tell it's mean from 500 meters away when it's just coming into focus!
https://www.sau.com.au/forums/topic/30059-spotted/page/105/#findComment-1137756
Hey Jayce - Spotted you too, Just In Time (JIT) mate. Concentrating on other things but thanks for the huge wave managed one back - did I look crazy waving hands all over the cabin... You guys did. Happy Chrissy and ya know Erica and the ScoobyRoo look hot!!!
See ya at the Jerra
https://www.sau.com.au/forums/topic/30059-spotted/page/105/#findComment-1137785
Spotted a complete tosser in a beaten up gunmetal R32 GTS near Woden plaza as it cut me off in the wifes XR6. Hope it wasn't someone on here, cos next time my kids mightn't be in the car and then you're toast....
https://www.sau.com.au/forums/topic/30059-spotted/page/105/#findComment-1138007
EDIT: Woopsies! Comming out of Blade 3 I Spotted the Incredibles LTSjayce and SRerica about to catch a movie. Cant remember the title tho....
John I was in Wodes about 20 minutes ago. Doesn't sound like my ride but I also encounterd a lot of tossers out there drivin below the speed limit almost holding hands. It was frustrating to say the least. It aint even Sunday!
https://www.sau.com.au/forums/topic/30059-spotted/page/105/#findComment-1138015
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
