Spotted SHY32R at the Nats scutineering.Wandered up and said g'day-top ppl! Oh,and yes-the car is a hard one!Also spotted that lovely pearled-up R33_377kw -too busy hunting down SHY32R to say anything more than a quick g'day:I'll endevour to catch you up soon to have a closer look!
https://www.sau.com.au/forums/topic/30059-spotted/page/109/#findComment-1146582
Spotted: Sinista in his R32 along parkes way or piallago way or whatever the road that goes to the airport is called. you wouldn't have seen me though, i was in my landcruiser
Yeah Soz - I didnt see ya. I am keeping an eye out for your Stagea tho.
SPotted in Braddon on the Strip. Phils nice Wine Red R32 GTR (Skyline Performance), Silver 33 (Wingless) one of the Trojan lads, all the Boyz (Andrew x 2, NiK, Ewen, Johnnyr31), Purple 33 and a few others. Had a few little squirts with the 33 on the way, nothing serious but a fun time.
https://www.sau.com.au/forums/topic/30059-spotted/page/109/#findComment-1147029
you need to come northside more often then mate, it's all happening up here :D
Anywho, i'll be out tomorrow night in full action with some mates of mine from bathurst. if you see my car, don't write on it, i'll clean it later.
https://www.sau.com.au/forums/topic/30059-spotted/page/109/#findComment-1147053
driving home just then from work down the monaro.
saw in the corner of my eye going the other what looked to be a silver R34 GTR...only saw the rear quarter, but definately looked like a GTR..also had a black GT wing
33 GTR with big chromies and NSW plates going down northbourne a few minutes before that
GTE, hehehe
https://www.sau.com.au/forums/topic/30059-spotted/page/109/#findComment-1147397
Ed's this morn.
Red/Silver R31, nice car Mark, Like your plans dropping in the NEO. Saw Jayce in Lycra on the tredley never a pretty site..He he he.
Ah,crap!My secret is out!!
Ah crap! So is mine!! (Nah it's no secret:))
Spotted in Woden last night a black or dark purple R33 GT-R
https://www.sau.com.au/forums/topic/30059-spotted/page/109/#findComment-1147646
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
