Spotted two white GT-R's leaving Wagga and heading for home this arvo, - very f'ing nice, was going the other way in my purple R33, gave you a little wave - not sure if I scored was back or was snobbed!
Hope you had a good day and enjoyed Wagga - just didn't quite make it back home in time damn it!
G'day Stolly:yep saw you wave-just managed to wave back b4 you were gone! Nice ride,BTW. That was me(pearl white 32),Sinista(silver 32) and Tridentt150v(black R33) just leaving when you saw us...
https://www.sau.com.au/forums/topic/30059-spotted/page/121/#findComment-1186934
my mate spotted (and keeps spotting) a marone 32 getting fully sideways (or fishy-ing) turning onto canberra ave near officeworks/fyshwick builders supplies (he works at the latter). he says he's seen him do it a stack of times, usually around the same time of day-ish.
thought i'd check to see if its any of you nutcases!!! hehe
d
ummmmm it might be me Sorrry :wassup:
https://www.sau.com.au/forums/topic/30059-spotted/page/121/#findComment-1186981
they are. i agree. i dont do sideways action anymore my wheels are too big and too expensive so i toned it down a bit. anyway enough of that. also spotted the 4 door silver r34 in jerra god i lve that car
https://www.sau.com.au/forums/topic/30059-spotted/page/121/#findComment-1187035
Spotted a gunmetal R32(GTR?) thismorning coming off the monaro highway out towards the airport, waved to each other
also spotted parked on Gladstone st a very nice looking 4dr R31. had frameless windows, and text on the side that indicated an RB20DET. looked very flash, i've never seen a frameless windowed R31 before.
https://www.sau.com.au/forums/topic/30059-spotted/page/121/#findComment-1187113
that's one of the import models
pillarless = classy :cheers:
there's one parked on lonsdale street all the time as well
https://www.sau.com.au/forums/topic/30059-spotted/page/121/#findComment-1187207
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
