Had a bit of a pleasant surprise at lunchtime
Was sitting at Barrow on the side of London Circuit having lunch about 12:15pm and started to hear a couple of distinctly different engines revving quite hard, turned my head and was greeted with a black VR/VS Clubsport having a very even run with a black R33...... neither looked or sounded stock
So I was like :headbang:
Whent he road straightened up the 33 must have grabbed 3rd and did a nice little sidestep...almost hit the Commodore though
in the end it was too close to call...... excellent I like it that way :kewl:
https://www.sau.com.au/forums/topic/30059-spotted/page/137/#findComment-1224033
yea i can probably go move it now but in the infinate words of andrew i cbf :) i must have rocked up only a bit after though only 2 spots down :(
also at least i could hopefully rely on you not to hit my door like half the others around here :) so far i am doing ok as the parks are reasonably wide plus i know most of the people who come by themselfs thus parking as close to their passenger door as possible :)
ps if the dude who owns that porsche works for teletech tell him to learn how to park ffs he is half out in the middle of the car park :kick:
https://www.sau.com.au/forums/topic/30059-spotted/page/137/#findComment-1224086
took my car for a drive a couple of hours ago and just as i got out of my street spotted a Midnight Purple R33 give it a hit around the next corner as i was approaching it and a red R31 with a BIG FMIC at the same corner.
Also spotted a black R33 with a skylines australia website sticker on the back window parked halfway up a STEEP driveway in Conder
https://www.sau.com.au/forums/topic/30059-spotted/page/137/#findComment-1224826
congrats Andy! i've always wanted to say "i've taken delivery of something" sounds cool!
should have mentioned, i spotted a very nice white R33 on hindmarsh heaidng towards woden just befire the red light camera after weston, i gave a massive wave as i paased and the dude looked a little surprised but then gave a nice wave back, nice to see!
https://www.sau.com.au/forums/topic/30059-spotted/page/137/#findComment-1224940
spotted a silver r33 non turbo in the narrabunda college carpark with Xforce exhaust, also a maroon R33 looked kinda stock parked on the top level of woden carpark today, and a dark green R33 looked stock also going down the highway that goes past woden plaza towards weston creek around 8am today
https://www.sau.com.au/forums/topic/30059-spotted/page/137/#findComment-1226354
That sounds suspiciously like mine... at my house. That's where it lives at night :) i hate the driveway, real pain, means i can't lower the car either.
https://www.sau.com.au/forums/topic/30059-spotted/page/137/#findComment-1226373
oh man this is starting to get really homo, who carries eggs around with them HONESTLY!?!? ok people, if your car gets egged put down all the info on them on the forums so then if we see them we can have a nice calm chat about what theyve done(MY ASS!!!!!!!), dam man thats FU(KED in the head!! i think we should all have a 12 pack of eggs in our cars from now on lol
https://www.sau.com.au/forums/topic/30059-spotted/page/137/#findComment-1226391
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
