Dude! Are you serious??? Who the hell does that? Someone holding a grudge? If it were me I wouldve jumped in the line and given chase! Believe me it works! Good you got the plates though! If you havent already ring the AFP and report it. Tell them you were struck by a projectile thrown/shot from a moving vehicle. Even if its an egg, its actually a crime you can be charged with. (yes I have had experience with a similar thing, long story)
https://www.sau.com.au/forums/topic/30059-spotted/page/138/#findComment-1226780
spotted Mick's GTR in the canberra centre carpark..
also saw my twin - another blonde female in a maroon R33 - ppl keep telling me they saw me somewhere (including my bf) when it wasn't me, i finally spotted her :D
also another maroon R33 with nice rims on Drakeford near athlon drive at about 7pm
https://www.sau.com.au/forums/topic/30059-spotted/page/138/#findComment-1228425
spotted my car up on the jack putting my new springs in :) i have put the fronts in but they dont look any lower :) i guess it may just take a bit of driving to let them settle but meh i only want it dropped 2 - 3 cm anyways so maybe cause it's such a little drop i havent noticed. Backs are going in tomorrow they look like a bitch to get to so the backseat will be coming out anyways just an update :P gauges maybe next weekend
https://www.sau.com.au/forums/topic/30059-spotted/page/138/#findComment-1229099
spotted my car up on the jack putting my new springs in :) i have put the fronts in but they dont look any lower :) i guess it may just take a bit of driving to let them settle but meh i only want it dropped 2 - 3 cm anyways so maybe cause it's such a little drop i havent noticed. Backs are going in tomorrow they look like a bitch to get to so the backseat will be coming out anyways just an update :) gauges maybe next weekend
You'll probably find that the front will look a bit lower when you put the lowered rears in, the stock rears are "lifting" the car atm, making it look a lil high
https://www.sau.com.au/forums/topic/30059-spotted/page/138/#findComment-1229253
spotted Veilside andrew out front of tuggerz today round 3.30 you were there for about 30 mins i was in my friends shop which was directly acroos fro where u parked, playing NFSUII the whole time :)
ah ok haha yeah i had the best shop of my life! i bought a pair of creme Kenji Urban cords, 2 pairs of Kenji slides (creme and black) 2 pairs of awesome "Mitch Dowde" boxers and a white singlet, all for $65!!!!!!!!! gotta love random 1 day sales!
https://www.sau.com.au/forums/topic/30059-spotted/page/138/#findComment-1229552
cheers andrew yea putting the rears shocks on in about 5 minutes :) so yea should be good will just need to get a wheel allignment and i will be happy :)
https://www.sau.com.au/forums/topic/30059-spotted/page/138/#findComment-1229575
lol no andrew i treat my car with respect :D haha well tey are all in and the back is sitting nicely front still looks a little high but i havent even taken it for a drive yet and i reckon it will settle down a little more. anyways have a good day all i am going to watch some baseball :D
https://www.sau.com.au/forums/topic/30059-spotted/page/138/#findComment-1229749
lol spotted a very nice wrx sandwich, i parked my 33 on the main strip in woden only to come back 25minutes later to find a crazy blue STI in front of me, with another blue STI in frotn of that, only to find Jon's PANADL 32 in front of all of us!!!
so the WRX's were sandwiched by 2 nice red Skylines, and it looked awesome!
https://www.sau.com.au/forums/topic/30059-spotted/page/138/#findComment-1229791
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
