Spotted my car with a nail lodged in the back wheel. What a way to end my long weekend.
Anyways, saw a white Series I R33 going into Civic. Guy in the passenger seat gave me the thumbs up. nice looking car, had a few stickers on it and a veilside rear bar.
https://www.sau.com.au/forums/topic/30059-spotted/page/147/#findComment-1260235
dunno. Driving back from the city i hear a clicking sound coming from the back wheel, pull over to look and there's a nail poking out. Surprisingly it also had the little metal ring around it as well, if it didnt have that the nail probably would have gone in flat and i wouldn't have noticed at all.
https://www.sau.com.au/forums/topic/30059-spotted/page/147/#findComment-1260336
also purple R32 at Mawson...sorry i shoulda waved but window was up, didn't think u'd see me anyway :) but i had a good perve at the car, haven't seen it before but i think it might be someone off here??
Yea that was me..
Saw you in the corner of my eye and when i looked i thought i saw you wave.. By the time i waved it was too late. Tinted windows with a hand behind... bit hard to see. :P
Also spotted like 100 lines over the weekend in sydney.
Few R32 GTR's
Few R33 GTR's
GTST's
Sh!t loads of Porche's
And a couple of Ferrari's
Oh and i played Inital D for the first time... and raced as the R32 GTR... funfun. ha
https://www.sau.com.au/forums/topic/30059-spotted/page/147/#findComment-1261011
Spotted PANADL headed towards porno town, on friday arvo.
Look'n nice bud.
p.s. I was the strange guy in the Green WRC Celica that waved.  :P
ah lol hahahahaahahaha i was thinking who that was. my mate was driving my car and he goes do u know that bloke and im like nope he must just like the car hehehehe. now everytime i see a green GT4 i gonna wave at ya lol. :rofl:
https://www.sau.com.au/forums/topic/30059-spotted/page/147/#findComment-1263366
"SPOOFN " is that the Purple 33 with GTR stlye wing and kit?
if so spotted on the monaro hwy on friday arvo, again I was in the celica.
He gave it a bit and I couldnt breath... needs tune and a bigger muffler, or, two of those... other wise looks good... even better once the damage is fixed :(
https://www.sau.com.au/forums/topic/30059-spotted/page/147/#findComment-1263808
Well if anyone spots me gimme a wave, im always poking around the place.
Cant miss my car, its like a patchwork quilt.
Things to look for:
Light bright grey undercoated rear guard (passenger side)
Red/burgundy drivers side mirror
Big dent in the bonnet
shitty painted front guard (passenger side)
Like i said cant miss it
Looks like a drift damaged R32
And i promise it will get fixed one day...
But yeah, Thats me...
https://www.sau.com.au/forums/topic/30059-spotted/page/147/#findComment-1264950
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
