spotted what i think was a defect station at the bottom of athlon drive, outside the electric station turning left onto erindale drive
one lane was blocked off, about 10+ cops, and 3-4 cars left on the side of the road. definately wasn't an RBT station, so my good money is on defect station, careful eh
https://www.sau.com.au/forums/topic/30059-spotted/page/179/#findComment-1423471
well i dont think mum's sss that i have today will get defected :) i am safe
https://www.sau.com.au/forums/topic/30059-spotted/page/179/#findComment-1423534
yep saw that as well, as i was heading towards woden...
hmmm i know i have some pickonable stuff.
yeah i'd be done hard methinks. mind you, there are other members of this fraternity (who might own r32 gtrs.. might be white...) who may as well just keep the KY in the glovebox... :confused: i don't even want to know how much out of pocket this person might be!!! haha
d
https://www.sau.com.au/forums/topic/30059-spotted/page/179/#findComment-1423856
spotted my mate telling me a R33 rolled yesterday at the Round about near lanyon. he said it was white, tried to drift around a corner, hit a gutter and then flipped. when i drove past today, all i could see was a big black mark on the gutter on the outside of the roundabout as if you were heading towards gordon (turn right towards tuggas, left toards lanyon or u-turn back towards calwell) i dont know if he was lying or not, anyone car to shed some light????
also spotted a gun grey R32 GTR on the same road, gave thumbs up and then a grey R33 gtst in tugags
https://www.sau.com.au/forums/topic/30059-spotted/page/179/#findComment-1424302
probably defects too...but mostly, they are checking for out of date rego..
I got done on Hindmarsh Dr a few weeks ago....same set up as what you described.
my rego was a few days overdue, I had to leave the car on the side of the road. All the other cars sitting there were for the same thing.
Anguss...that doesn't sound good ;)
https://www.sau.com.au/forums/topic/30059-spotted/page/179/#findComment-1424626
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
