Mucho Skyrine on ze way home about half an hour or so ago
- Passed the other way on Adelaide Avenue, a silver R33 GT-R, black aero bonnet, looking rather evil
- Silver R33 with bodykit & multispoke mags on Melrose Drive coming up to traffic lights @ Hindmarsh Drive
- Silver R33 GTS-25t 4 door, turning right onto Hindmarsh Drive heading towards Weston Creek
- Burgundy stock looking R33 series 1 heading towards Woden on Hindmarsh Drive
- Gunmetal Grey R32 GTS-t right behind the burgundy R33.
So that's 5 in about.... 3 minutes :rofl:
https://www.sau.com.au/forums/topic/30059-spotted/page/183/#findComment-1450386
you couldnt have put more neons in that thing is like one moving neon already :P
aaah andy you and your bloody schneonzz. we need the bling patrol to pay you a visit methinks. where be them now? and if you ever buy iceled's i'll disown you forever. :(
saw those bloody things on a white mirage/droid kit/vaults in civic on the weekend and i nearly vomited (and i did later on that night anyway hehe).
d
https://www.sau.com.au/forums/topic/30059-spotted/page/183/#findComment-1450429
HI MY NAME IS THEO ....TROJAN IMPORTED MY CAR LAST YEAR AND I WAS LUCKY ENOUGH TO GET A ONE OFF FIBERGLASS BOOT.
Hi Theo, i think i might of seen your car before? Dont know.......
Maybe you should DRIVE IT MORE :bonk:
Or you to scared hehehehe :D
https://www.sau.com.au/forums/topic/30059-spotted/page/183/#findComment-1451397
