theres just something about the rain. all of a sudden, people either drive too slow and cause problems that way, or too fast, not knowing what wet, oily and slippery roads can do and they seem to instantly become 100% retarded. that and when its wet, every pimply-faced 17year old commonwhore p-plater with a monster tach and a backwards cap thinks they've become schumacher... bloody rain...
:soap:
d
https://www.sau.com.au/forums/topic/30059-spotted/page/184/#findComment-1451813
I've actually noticed with the rain we've had over the past couple of weeks when I drive to work in the morning up the Parkway that when it's wet, the majority of people are actually driving faster than they do when it's dry.
Silly isn't it
https://www.sau.com.au/forums/topic/30059-spotted/page/184/#findComment-1452051
Spotted :  My Stagea driving down the road without me in it !!  Sold it last night :)  sad to see it go but it'll be looked after well.
So, anyone got a $500 crapbox with rego they wanna sell ?
Congrats - didn't take long. Is it staying in Canberra?
Marc2
https://www.sau.com.au/forums/topic/30059-spotted/page/184/#findComment-1452242
G'day Marc,
Yep, Andrew is right, it's off to Tassie :) I was expecting it to take about 3-4 months to sell but it was snapped up in just under two weeks from when I put the for sale post up !! It had a full NRMA inspection on Monday morning, price agreed on Monday night and he flew up on Wed.
Because it went so quick I'm left without a car :D hence why I'm after a little bomb for a few months.
Thanks Leigh, yep I'll be hanging around the forums for a while, and if you see someone in a heap of crap car wave at you then you know who it'll be :)
J
https://www.sau.com.au/forums/topic/30059-spotted/page/184/#findComment-1452301
J
Usually when leigh sees a heap of crap waving at him its in a mirror.......... :Owned:
possibly my best call ever!
https://www.sau.com.au/forums/topic/30059-spotted/page/184/#findComment-1452380
G'day Marc,
Yep, Andrew is right, it's off to Tassie :rofl:  I was expecting it to take about 3-4 months to sell but it was snapped up in just under two weeks from when I put the for sale post up !!  It had a full NRMA inspection on Monday morning, price agreed on Monday night and he flew up on Wed.
Because it went so quick I'm left without a car :P  hence why I'm after a little bomb for a few months.
J
Wow - that certainly makes the ACT based STAGS nearly as rare as 3 legged bandicoots.
Marc2
https://www.sau.com.au/forums/topic/30059-spotted/page/184/#findComment-1453061
oh which reminds me, i spotted that green stagea in woden yesterday.
i have to change my sig Leigh actually, Gus has changed his, anyone have any humerous iseas for the next sig?
Leigh you now have the right of rebutal for the next call
https://www.sau.com.au/forums/topic/30059-spotted/page/184/#findComment-1453113
Marc2
Yep, getting pretty rare here now.. I wanted to catch up with you and Term' for a few pics before I sold her, but it happend way too quick :P
Maybe in a few years you'll see me in a 260r :rofl:
J
https://www.sau.com.au/forums/topic/30059-spotted/page/184/#findComment-1453326
J
When I sought out the SII, will give you a 'heads up' and you can have a drive - just to realise what you are missing out on.
Marc2
https://www.sau.com.au/forums/topic/30059-spotted/page/184/#findComment-1453384
Marc2
;) thanks, I think ;)
I've got no car at all now, and Saturday looks like it'll be rained out so I might not get a chance to check out all the car dealerships :( Looks like the bus for me for a while...
J
https://www.sau.com.au/forums/topic/30059-spotted/page/184/#findComment-1453956
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
