spotted - heaps of lines (2x white 33's 3 x32's, a 4 door 34) at stonefest last night.
and god do i feel rough!!!!
d
One of the white R33's was mine, nice to meet you djhatton! Yeah i think im going to feel rough all this week. :D
Big thanks to the bloke with the White R33 that stopped when my car was on the side of the road broken earlier this arvo
No worries. Glad to hear it was only a simple problem. Very nice car by the way :(
https://www.sau.com.au/forums/topic/30059-spotted/page/227/#findComment-1677654
Yep me too. It made me smile when I saw the indicators flashing on and off... It was a very good way of making a point! :lol: Ever feel like your being watched :)
I couldnt help have another look though. *Drool*
I hardly drive mine but when i do its where I can see it! I even park it in a spot I can see from my desk when I drive it too work! :lol:
Edited by Stevie
https://www.sau.com.au/forums/topic/30059-spotted/page/227/#findComment-1678367
I swear i flogged the pants off that car or one similiar at the lights near Canberra Hospital ages back while I was getting my car registered.
It was a good day.........
https://www.sau.com.au/forums/topic/30059-spotted/page/227/#findComment-1679170
Spotted slither in civic this arvo about 5:30, drove past me but i was in the girls car
wasn't me dude i was at home by 5:30 theres a burgendy r33 with a 400r front by and my wheels around tho
spotted johny r31 in fyshwick today
Edited by Slither
https://www.sau.com.au/forums/topic/30059-spotted/page/227/#findComment-1679191
yea that was me i spotted you as well was gonna wave but you wernt looking. i figured it was you though it sound very N/A :P
Yeah, it was missing the whole 'pshtt' side of things;) It was a little hard to see you as the sun was in my eyes:P Was trying to keep an eye on the road too :lol:
Sweet as cooler but bro.
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/227/#findComment-1679218
cheers :) yours looked like a nice package not over the top suited it also what colour is yours it looked sort like black/grey ???
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/227/#findComment-1679392
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
