hi mate
Any idea where i can get a new exhaust... im sad, apparently i got ripped off about something else (look what happens when you trust car dealers) and my exhaust is only cat back, not turbo back...
I either need to get the pipe from turbo to cat, or a whole new system
Cheers
Heath
https://www.sau.com.au/forums/topic/30059-spotted/page/228/#findComment-1679968
friends have recommended powatone in fyshwick, however i've gotten expensive quotes from them
otherwise city custom exhaust in braddon
Cheers, might try the lads in braddon... sorry about that message being in this topic
https://www.sau.com.au/forums/topic/30059-spotted/page/228/#findComment-1680041
haha scare with the alarm thats a good one....mick you have coffe often or something because your always parked there!
also stevie, i saw you in woden on friday i think walking past vodaphone...i called out but no no1 remembers the young kid :angry:
hows the car coming along?
Yeah that was me! You called out? You need to speak louder! Too much bass makes Stevie go deaf!
My car was parked in Micks spot that afternoon! I'm suprised nobody spotted it on one of its rare appearances???
Its coming along nicely. Its back on the road. The kit is still a work in progress though. It should be finished in the next couple of weeks! And once thats done I just have to slap together a couple of gfb's that i'm hanging out for... I have a couple of wish list items that may take a bit longer to arrange though. Hows the R31 coming along? Does it exist yet?
https://www.sau.com.au/forums/topic/30059-spotted/page/228/#findComment-1680314
I just hooked a mate up with a GREAT deal with Trojan. I would really recomend talking to them before you pay about $500+ too much at other mentioned businesses. :angry:
https://www.sau.com.au/forums/topic/30059-spotted/page/228/#findComment-1680316
at the moment there is a fund for the goodo 31. im gonna wait til i have my p's before i buy a car, then i can get one thats as clean as possible and with more mods than a stock one, if you get me. i'll be looking for a nice silo, or maybe a coupe. OR if i ahve enough money at the time, ill go for a R32 gts.
but all that said, whatever i get will be a weapon and i can garuntee that! i can already see me putting all my money into the car!
when do i get to go for a run in urs :) i wanna hear this bass! hehe :)
https://www.sau.com.au/forums/topic/30059-spotted/page/228/#findComment-1681280
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
