Gunmetal R32 GTR heading north on Cwlth Ave today around lunchtime, nice car.
thanks scooby, that would've been me heading to work..
spotted today, maroon or red r32gtr on northbourne...sorry Im a bit colour blind... very neat and the mags looked awesome
also spotted on saturday, viper at the soundoff at jb in woden
https://www.sau.com.au/forums/topic/30059-spotted/page/233/#findComment-1698939
'mines at some place in fyswick'
'Spotted Leigh's car at said place in Fyshwick, mine's there too!'
'thats funny is ben doing work on yours too or is it the un-named place :)'
very cloak and dagger.
'Go to a warehouse in Fyshwick. Be careful. There you will meet Tuna er Tuner, and he will introduce you to the killer, Watts. Be careful if there is someone from China called Hybrid, he may be a copy. Trust no one and Greddy to split if you feel too much heat. Advance as much as you can but back off so you don't get knocked. If you're in trouble, Pon cam not help until later and neither cam Wheel as they've been told to strut some bar. If it all goes bad then just think quick, shift.'
OK so I'm bored.
https://www.sau.com.au/forums/topic/30059-spotted/page/233/#findComment-1700902
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
