Spotted a wine R33 at phillip shops today, had a maroon licence plate with 3 letter on it, also a sau sticker on the back. female driver gave me a wave.
that was meeeeee!!!!
hope you got a park...what a shit fight that place is lol
https://www.sau.com.au/forums/topic/30059-spotted/page/253/#findComment-1797505
she was blonde if that helps ID the one i saw. cloning programme?
if she was blonde then that's her! I have no idea if we actually look alike...but anyway..check for an SAU sticker on the back window! And red numberplates..
https://www.sau.com.au/forums/topic/30059-spotted/page/253/#findComment-1797571
oh i spot of the day was on the way to the dyno day just as i was about to turn into the street with the rest of the cars who should pass me... the chamelion/purple r34 gtr very horney almost creamed my pants then 2 cars behind the white r34 gtr bam it was all over i lost it was very excited to see these two :P
https://www.sau.com.au/forums/topic/30059-spotted/page/253/#findComment-1798817
spotted Terminal on the way home last night at about 12 ish, you were going up along adelaide ave towards civic......
Yeah mate i saw you too, was on my way back from movies. took the girl to see the new Harry Potter movie, was good.
https://www.sau.com.au/forums/topic/30059-spotted/page/253/#findComment-1799191
Spotted Jayce and erica at Manuka havin Coffee....
HI!!!!
And I wasn't even in my 'Line! Also spotted a white R32 GTR with white wheels,driven by a female,in Manuks about 7.30.Anyone here?
https://www.sau.com.au/forums/topic/30059-spotted/page/253/#findComment-1799830
spotted silver 33 gtst heading into civic last night 10ish. cute blondie behind the wheel.
spotted red 31 2-door with coooool oldschool dinner-plate/moondisk style wheels and big fmic + nsw plates (as well as lots of messed up people like eeeewin and mark) at evolution (greg packer/pendulum@ucbar) last night.
d
Edited by djhatton
https://www.sau.com.au/forums/topic/30059-spotted/page/253/#findComment-1799857
i think its a southside car, i see it now and then. i dont think she is on here, as every time i see it, i get snobed...... or maybe she just hates me :D ?
https://www.sau.com.au/forums/topic/30059-spotted/page/253/#findComment-1800519
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
