yeah jon it still is, although nath isnt on here much anymore, hes too busy with CanberraCruises now :P
id buy it, but... you know...
Well i messaged him about it. He has never gotten back to me. I wouldnt mind buying it back lol
https://www.sau.com.au/forums/topic/30059-spotted/page/325/#findComment-2454200
well im positive he's still got it for sale
heres the link for the FS thread on CanberraCruises:
http://www.canberracruises.com/forum/showthread.php?t=1445
did a search on carsales for the add. doesnt seem to be there.
Edited by SKYLVIA
https://www.sau.com.au/forums/topic/30059-spotted/page/325/#findComment-2454641
Well i wonder why he didnt reply to my sms then. Maybe a different number. I love the car it is so nice
https://www.sau.com.au/forums/topic/30059-spotted/page/325/#findComment-2454653
Gotta say Jon + PANADL went hand in hand... EXCELLENT GTS-T,that one! How's the Melb' scene,Jon? We miss ya up here!
Yeh they did go hand in hand. the car loved me as much as i loved it lol.
Melb is awesome jayce. its really good. lots to do etc. You should come visit one day. I am starting to miss act beleive it or not. Must be the peacefulness of it. never know might be back one day. Hows the Beauty "R" going??
https://www.sau.com.au/forums/topic/30059-spotted/page/325/#findComment-2454782
Spotted a young cute lass driving a S1 33 with P Plates and purple seat covers in Tuggers next to Tyrepower.
was it black and on its arse?
1. shes not hot
2. shes a bitch
i inched past her car today in a car park as she cut the corner and took up all the road.
"just you watch my car!"
:(:D f**k you cow!
https://www.sau.com.au/forums/topic/30059-spotted/page/325/#findComment-2456185
spotted a silver R33 turning into Dickson at about 5pm
it had rims with lots of spokes..dunno what they were.
guy in his 20's (??) driving with a cap on... I was waiting for you to look over so I could give you a wave but I don't think you saw me.
https://www.sau.com.au/forums/topic/30059-spotted/page/325/#findComment-2456332
Slowly,LOL! The expected build up will take more time,funds and trick parts than I envisioned,but it'll be worth the wait! And I'll get to Melb' soon:have to buzz ya to catch up for a drink!
https://www.sau.com.au/forums/topic/30059-spotted/page/325/#findComment-2456931
Sounds like El Frinko.
https://www.sau.com.au/forums/topic/30059-spotted/page/325/#findComment-2457235
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
