p1r4t8r - I used to see your ride all the time parked at your home. Havnt seen it for months and thought you must have sold it. Travelling past that way a few times a week too. U still out this way ?
Will have the stez hooked up again soon but surprised you havent heard the zorst anywayz.
https://www.sau.com.au/forums/topic/30059-spotted/page/329/#findComment-2486664
I spotted a high speed chase going around my street tonight. some guy in a BA XR8 was trying to outrun 2 cop cars, although he seemed to have sustained a fair amount of damage to the rear of his car, and was missing his rear right tyre. he was grinding the rim along the road while revving the guts out of it to keep going. it was pretty cool, but i live in a circuit, so he went past my house, came out the other end of the circuit, then decided to go around again. the cops split up, obviously trying to stop him at both ends, but he just went around them, then spun out, kept it going and went down the street. i think they finally caught him down on kingsford smith drive, but it was still pretty cool. the noise was horrific, grinding rim and revving V8 combined with the 2 police sirens. i'm sure we'll read about it in the paper tomorrow or see it on TV
https://www.sau.com.au/forums/topic/30059-spotted/page/329/#findComment-2491558
hahaha thats crazy!
I was wondering why they blocked off the entrance, they'd only do that if something major was going on.
I kinda crapped myself when i read that coz my brother drives a BA XR8 and just after i saw the cops i saw him having a bit of a run against some bogun ute...
All good, wasnt him haha
https://www.sau.com.au/forums/topic/30059-spotted/page/329/#findComment-2491794
Yeah, i don't leave it out anymore, always in the garage. It used to live outside for a bit before the garage was cleaned out. i was a bad owner :sick:
I remember seeing your car going past a bit, i'd always look out the window and drool. lol.
https://www.sau.com.au/forums/topic/30059-spotted/page/329/#findComment-2491892
i dunno, but i had my car parked on the street and i watched this guy fishtail past it with no rear tyres. there's an awesome line coming up the road now from the rim digging into the road. i wouldn't think you'd try and outrun the cops if you'd just stolen a car. i saw the guy in the car as he went past, he was all suited up. He didn't really look like the sort of person who would steal a car.
https://www.sau.com.au/forums/topic/30059-spotted/page/329/#findComment-2492250
lol, they just mentioned it on the news update, they said the suspect rammed 2 police vehicles and got away, he is armed and dangerous and not to be approached if seen but to contact the police immediately.. His name is David McGloclan i tihnk, must be in the belco area somewhere..
https://www.sau.com.au/forums/topic/30059-spotted/page/329/#findComment-2493604
It was a BA GT... my bf saw the car smashed up on the side of the road, then spoke to the cops about it - they said to look out for a guy in a white tracksuit (haha!!)
anyway they seem to have got him this arvo, finally...
http://www.abc.net.au/news/newsitems/200609/s1741277.htm
https://www.sau.com.au/forums/topic/30059-spotted/page/329/#findComment-2495086
haha either he's loaded or his insurance company is damn good!
and yeah the knobhead shot himself.. he's in hospital
http://www.abc.net.au/news/newsitems/200609/s1741429.htm
pity he didn't do a proper job of it :)
https://www.sau.com.au/forums/topic/30059-spotted/page/329/#findComment-2496300
Normally,I'm quick to jump to the 'natural selction' defence when people put themselves into a stupid predicament,but how bad must life have to seem to top oneself? Sad...
https://www.sau.com.au/forums/topic/30059-spotted/page/329/#findComment-2496534
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
