i spotted a white R33 gts-t with white wheels, M-spec kit (skirts anyway...) and an exhaust going southbound along adelaide ave this morning at around 9.45am ish.
also spotted a mysterious looking black R32 gts-t heading north along adelaide ave this evening at about 9.30pm ish. it had a bodykit of some kind and black wheels. it was dark, so i couldn't see it properly, but man it looked hot!
and lastly, i saw Rachel going up yamba dr towards woden shortly after i saw the black R32. i waved, but i was in my R31, so i didn't expect you to notice me. had i have been in my R33, well that would be a different story...!!! HA! :)
https://www.sau.com.au/forums/topic/30059-spotted/page/335/#findComment-2538648
Spotted a gold 33 with a big fmic and a flush bootlid on the way home from work. Looked awesome. Possibly had a black/carbon bonnet too... Don't really remember now. Anyone else seen this around?
Could be the same one I have seen out at Jerra. Very nicely done isn't it.
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/335/#findComment-2541019
Spotted that one lastnight cruising around braddon and civic - gave a wave and a nod, got one in return.
Looks nice as!
https://www.sau.com.au/forums/topic/30059-spotted/page/335/#findComment-2541743
In Fyshwick earlier today????
Jayce? >_<
Mmmm...32 goodness! Is there anything better? I think not!! Heard you two were up to no good,LOL!
Also spotted a black 32 with nice shiny rims,followed by a black 33 with nice shiny rims,driving across Dairy Flat Road towards Fyshwick about 5.45 yesterday arvo';looked like formation driving in an overly police-aware state...
https://www.sau.com.au/forums/topic/30059-spotted/page/335/#findComment-2543016
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
