spotted a white R33 with R34 stockies on drakeford drive this morn near Kambah.
:D Me, my first spot. Was just at ACT brakes to get roadworthy but forgot it had to go through dickson for ID check first.... so now i have to wait till next thursday till its registered. :laugh:
https://www.sau.com.au/forums/topic/30059-spotted/page/346/#findComment-2600453
:) Me, my first spot. Was just at ACT brakes to get roadworthy but forgot it had to go through dickson for ID check first.... so now i have to wait till next thursday till its registered. :laugh:
haha you wouldnt have seen me, i was hiding in my corrola govi car :rofl:
https://www.sau.com.au/forums/topic/30059-spotted/page/346/#findComment-2601147
Got/gave a wave to a fellow in a silver R33 GT-R with a carbon fibre bonnet at the BP in Phillip this arvo.... tuff arse car you have :)
I saw that in phillip too!! and I saw you too but you werent looking!
also saw the other car that looks like yours but not with blue plates... he was parking outside Babar and appears to be BLIND haha (jokes) ...cos I was stuck in the traffic right next to you as you were parking and getting out of your car and you didnt even notice :)
also spotted gunmetal R32 go past BP phillip
and a black R33 in the Ampol Kambah
https://www.sau.com.au/forums/topic/30059-spotted/page/346/#findComment-2601355
A wine red r33 down tharwa drive (past lanyon shops) late this afternoon (prob around 4ish), def got my attention pretty loud..
In the lanyon car park a black r33 with a im greddy sticker on the back window.
A black r33 down hume highway around 1 pm, and a white r33 near theodore prob about a hour later,
https://www.sau.com.au/forums/topic/30059-spotted/page/346/#findComment-2604335
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
