Spotted a couple of maroon R33's today, but i'm not driving the stagea anymore. My missus will hvae it until her car is fixed then it's going into hiding for a while. keep a lookout for a white Toyota Chaser Tourer V with NSW plates.
https://www.sau.com.au/forums/topic/30059-spotted/page/371/#findComment-2821641
Spotted 3 Black 33s and a Silver 32 today
2 of the 33s were parked in northside frontyards, other was near erindale at around 6pm
Silver 32 was heading into Woden around 5:30
forgot, saw a red 31/30 (know nothing about those cars :)) at the carlovers in erindale
Edited by Baconer
https://www.sau.com.au/forums/topic/30059-spotted/page/371/#findComment-2821852
