you bastards.
i asked if there was going to be cruising, and most of you turned around and said nah.
bugger i was always up for a cruise, sorry you missed out mate, donnan showed up later aswell
I'd blame low200 cos i was late so i can't be blamed lol
https://www.sau.com.au/forums/topic/30059-spotted/page/396/#findComment-3003126
spotted sinista at the BP servo last Friday (would have posted earlier but have had no internet :) ). Had a chat and even managed to talk him into giving me some money.. hehe ;)
I see you made it to the dinner then Richard.. going by posts above ^^ ...unless you just went cruising :D
https://www.sau.com.au/forums/topic/30059-spotted/page/396/#findComment-3008258
Gave/got a wave from a maroon 33 waiting at the closed off road thing they have going on on Cotter road, and gave a wave to a silver stagea coming up the hill on william hovell drive, but received no love in return :)
'twas probably my car, but the missus would have been driving.
Spotted Luke in his White Stagea going past Calvalry hospital this arvo, shiny new wheels.
https://www.sau.com.au/forums/topic/30059-spotted/page/396/#findComment-3010262
Yea i got an pm/invite about it but was in Melbourne... PGA (Pulsar Group of Australia) had a meet up and a fair few guys/gals from Sydney came down.
oh and about a million pulsars in woden on sunday (what is the collective of pulsars? an sr20 of pulsars?)
https://www.sau.com.au/forums/topic/30059-spotted/page/396/#findComment-3011540
Just had a Moron, I mean Moroon 33 tailgate me through Weston towards Kambah. If your on here, next time back off would ya, I couldnt see shit from those bright arse headlights (or were they highbeam?). (i was in the troopie)
https://www.sau.com.au/forums/topic/30059-spotted/page/396/#findComment-3014185
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
