Saw white series II R33 heading off tuggers parkway onto livingston i think its called at about 7:20pm tonight (turning right at the start of Kambah)..
Who owns this? Looked very nice and clean, nice note too - i would like to see more pics - the front bar looked stock-ish maybe a tommy bar or similar i only caught a very small glimpse ...looked much nicer than mine though :P
No one owning up to this? Looked and sounded nice, would like to know a bit more about the car.
https://www.sau.com.au/forums/topic/30059-spotted/page/400/#findComment-3036339
spotted my car in that pic, bam :P
that was the first car that came to mind aswell, have seen it in another pic somewhere on the forums, lives in another state
ahh ok...just that the plates are ACT rego
Edited by zooee
https://www.sau.com.au/forums/topic/30059-spotted/page/400/#findComment-3036691
It might be my friends car, she drives a White series 2, did it have a GTR wing and front bar? Her boyfriend lives in Rivette so they could have been in the area.
haha cheers, whoever it was gave it a boot through the lights. I am having a very short break from performance mods and looking at cosmetic issues so looking at a lot of body kits/wheels etc.
https://www.sau.com.au/forums/topic/30059-spotted/page/400/#findComment-3036953
it was'nt that series 2 that was at the shannons show n shine parked next to me u know the one it had aj personel plates
this one
definately could have been this one, looks very clean and neat. mine needs a respray, new skirts, new rims etc...
https://www.sau.com.au/forums/topic/30059-spotted/page/400/#findComment-3036965
Spotted something rare in Weston this afternoon, not a Skyline, but worth a mention
Drove past a silver Z32 300ZX with a peculiarly familiar set of side stripes - upon closer examination... Tommy Kaira M30Z!
https://www.sau.com.au/forums/topic/30059-spotted/page/400/#findComment-3037813
ouch!
i spotted leech (his Mrs anyway...!) this morning driving to work. i waved but got nothing back as per usual... :dry:
also yesterday, spotted a white s2 R33 parked on the meduim strip of Canberra Ave in manuka at around 11.45am. had an exhaust and no rear wing...
https://www.sau.com.au/forums/topic/30059-spotted/page/400/#findComment-3040794
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
