haha I too received the 'small dick' signal yesterday, simply because he wanted to jump across into my lane so he would be first at the lights, I wasn't even going fast at the time, I think he was just p!ssed off because he didn't think quick enough. I wonder how he felt when he realised I was a 'no dick at all'? Made me chuckle anyway LOL
I hate when people do that, especially when im in the work truck, so hard to stop trucks...
A no dick/ a fist with no fingers raised sign thrusted into the air would be more hurtful to me if i was a girl, it would be as if they were questioning my (I couldnt think of another word for skankish behavior, all that kept coming to mind was 'vaginal elasticity' so i didnt write anything at all :X...), that or they were threatening some girl bashing
Edited by Baconer
https://www.sau.com.au/forums/topic/30059-spotted/page/426/#findComment-3265341
I mad eye contact with a driver of a black 32 in banks this arvo. For some reason I just stared at him as I drove passed. He pulled over for some reason. But it was just a mind freeze and I just looked at him. Sorry if I scared you.. hhaha
https://www.sau.com.au/forums/topic/30059-spotted/page/426/#findComment-3269886
Spotted a silver series one 33 with black racey looking rims and a Trojan sticker up at the marketplace yesterday. Who’s car is that?
The spare parts guy who works at Trojan has a Silver 33 and same rims as mine - only he has painted his black. Can't remember his name, but he's a nice bloke.
https://www.sau.com.au/forums/topic/30059-spotted/page/426/#findComment-3271193
just spotted one of the sexiest R33 GTR's ever on the surfers paradise. (my opinion only:))...
A Red(fairly bright) with what looked to be 19 or 20" Volk CE28's or something similar this thing also had the sound to back it up certaintly sounded like it had some serious work done unde the hood. Hopefully he/she is on SAU i might check the QLD section.
https://www.sau.com.au/forums/topic/30059-spotted/page/426/#findComment-3271744
haha the blonde in the black vectra? I saw another VERY hot girl in a black vectra this time with black hair (my weakness haha) she was gunning around driving like a nut so i pulled up next to her at the next set of lights and showed her whats for, with the new exhaust it made an ungodly amount of noise (love this exhaust, quiet when normal revs but absolutley screams above 5k, but it was all worth it for a smile from the hotty, high school all over again :P
whats with hot chicks in black cars?!?
Spotted a stunner in a black VW turbo on my way home today past tuggeranong almost wrote off the commy lol
https://www.sau.com.au/forums/topic/30059-spotted/page/426/#findComment-3271828
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
