Spotted a red R33 going towards Woden at about 3:40pm on Athlon Dr.
Now, what was that number plate - WTF!!!! ;)
it's not WTF!! :)
I did see the R34 but only at the last minute.... thought it might have been you!
https://www.sau.com.au/forums/topic/30059-spotted/page/461/#findComment-3617601
Yep; the grey 35R is definately Bob's. And Jerry tells me he doesn't have one, which is good enough for me. Whilst the car isn't complianced, it seems a mere matter of time, tests and red tape before Bob gets to drive it on the roads. The question I need to ask him is what he's done with his daily driver 34. Would be a nice garage: 33,34 & 35 model GT-R's!
Spotted today: a black 32 GTS-T, nice wheels, well fitted FMIC, driving into Fyshwick as I was passing through. Saw the driver looking, so I waved, but it mighta looked a bit weird...getting a wave from a gold Forester! I long to be more recognisable behind the wheel of a certain white 32.
Not to mention the Z32 300ZX TT and Soarer and I do believe he has a GU Patrol as a tow car... He was getting around in a Ferrari 355? not long ago too. It wasnt his though.
https://www.sau.com.au/forums/topic/30059-spotted/page/461/#findComment-3618519
Hey Jayce, whats happening with the old girl?? Still no go with the build yet?
Yes, yes; don't remind me!! LOL!! Still, forward progress(with the build) will be resuming shortly...
Spotted at 6.20 pm, on the Monaro Hwy southbound, a white Stage with Qld rego (I'm pretty sure). Seemed neat, the little I got to see of it!
Also saw a yellow 200SX at about 6.40 pm leaving little Jerra' shops, rego' was something similar to 'YCZ' something-or-other, P plater. also a complete tosser, pretending to be a drift king on a narrow street. It would have distressed me to see one of Nissan's nicest sports cars get pranged. However, I wouldn't have minded seeing his fulsik chromies take a beating on a gutter to wake him up. F**king goose. Whilst he's not likely on here, if anyone floats between here and N.S. dot com, maybe a quiet word in this loser's ear if you know him, please?
End rant.
https://www.sau.com.au/forums/topic/30059-spotted/page/461/#findComment-3619629
hehe i was sitting in that very car yesterday :banana:
the owner is on here but very rarely..
I spotted a black R33 in kambah yesterday afternoon... had massive for sale on the back and was driven by a chick with dark hair.
https://www.sau.com.au/forums/topic/30059-spotted/page/461/#findComment-3619660
spotted a very nice 33 on the Barton HWY (Canberra side), bronze/gold colour.
gunmetal 33 in Woden (parked)
also spotted what i think was a Jaguar XK (going by brief view rear lights and side on as it drove through traffic lights, looked like it had the chrysler badge on the back though :X) in fyshwick around 4pm. It was ridiculously hot.
https://www.sau.com.au/forums/topic/30059-spotted/page/461/#findComment-3623447
That was meee. Hahaha I don't even live in Belco anymore and when I go there once in a blue moon I get spotted biggrin.gif
Hahaha I live on the Southside and it's the first time I've been to Belco in ages! *cue twilight zone theme*
https://www.sau.com.au/forums/topic/30059-spotted/page/461/#findComment-3629322
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
