wildthe sphincter of the universe72 please don't report locations of parked cars. Can you please edit your post? Cheers mate.
no probs mate, i didn't think it was too specific, and if you read the last 2 pages you will see much worse than i have said, but i'll edit it for you :D
https://www.sau.com.au/forums/topic/30059-spotted/page/467/#findComment-3679890
Spotted a black 33 GTR on barton hwy. Looked over but he was a real snob....to cool for school.
I've been getting a few of those of late, here's me waving and grinning like a right w@nker (shup Mick) and they stick their nose in the air.
https://www.sau.com.au/forums/topic/30059-spotted/page/467/#findComment-3680747
yup, I tend to not wave unless someone waves first, or I know the car/person, or it's easy to throw an arm out the window as you go past & if they don't wave back then who cares.
Been burnt too many times!!
https://www.sau.com.au/forums/topic/30059-spotted/page/467/#findComment-3680832
Saw a black R32 GTR (YGT ***?) in Civic about 15 minutes ago, dropping a huge ploom of unburnt fuel out his exhaust as he booted it to try and catch an amber light.
Yay I was spotted! Would be happy if it was unburnt fuel :thumbsup: , oil unfortunately.... the baby will be going in for a rebuild in the not to distant future. Sorry for the smokescreen!
Cheers,
B
https://www.sau.com.au/forums/topic/30059-spotted/page/467/#findComment-3683410
I've probs seen 3 lines since i got mine and they've given me nothing. WHATS WRONG WITH YOU PEOPLE :D
There used to be alot more love
https://www.sau.com.au/forums/topic/30059-spotted/page/467/#findComment-3683765
no probs mate, i didn't think it was too specific, and if you read the last 2 pages you will see much worse than i have said, but i'll edit it for you :turned:
I didn't mean to come off angry - sorry mate, it's been a really trying week and my fuse is short right now. sorry!
https://www.sau.com.au/forums/topic/30059-spotted/page/467/#findComment-3684166
nope, half day of work so have been lying in a hammock or riding dirt bikes all day. Have driven the skyline twice in the last 2 weeks :X
Spotted a Silver 33 with complete 400R bodykit driving past the braddon BP and a maroon 33 turning into the canberra center carpark around 2:30pm (was in the mushroom truck)
Edited by Baconer
https://www.sau.com.au/forums/topic/30059-spotted/page/467/#findComment-3685815
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
