Have spotted too many to mention.
My white R32 GTR is currently, wingless, sideskirtless and minus front lip.
I try to give a nod or a quick wave if I see another skylines on the road.
Anyone know who owns the white R32 GTR with the Trust front bar? only saw it once but looked very nice.
https://www.sau.com.au/forums/topic/30059-spotted/page/520/#findComment-4283729
