Hey guys was heading back home on cabramatta road in southwest sydney, and came across a orangy coloured R34 with ACT plates YER ??? was looking hot, was tailing him in a black 4 door R34, don't know if they are on here, just adding him to spotted :D.
https://www.sau.com.au/forums/topic/30059-spotted/page/561/#findComment-4648174
Saw most likely the same car parked in Civic around lunchtime, looks like an ADM model.
Yeah, it was about lunchtime when i saw it. Also i think i've seen you a few times blueprint. Have you parked your 31 along the back road next to the Customs building a few times?
https://www.sau.com.au/forums/topic/30059-spotted/page/561/#findComment-4648218
Once or twice, I rarely drive to work.
https://www.sau.com.au/forums/topic/30059-spotted/page/561/#findComment-4648259
Passed a white R33 coming out of Woden Plaza carpark... didnt recognise the driver but he didnt look at me anyway so I didnt wave..
Also a silver R33 at Phillip just down from the BP, I think its a bike shop there?
i might have been the white skyline at woden... if it was a rainy day i would have driven in..... thats if it was a white series 2 with gold mags....
https://www.sau.com.au/forums/topic/30059-spotted/page/561/#findComment-4655460
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
