Haha sorry Trozzle.
I've been informed that there is a thread going on somewhere that you can post in to get your name changed (thanks Shell).
I changed mine just to have a bit of anonymity since my previous one was pretty much just my name.
https://www.sau.com.au/forums/topic/30059-spotted/page/589/#findComment-4878973
Too true. Thankfully my first name isn't really a concern for ppl to know, but in your case it was your surname out there as well :thumbsup:
If I had my surname in mine, only like 5 of it in the phone book, all related. Hell, only like 5 of us in Australia...too easy to work out who/where I am.
Anonymity is the way to go
https://www.sau.com.au/forums/topic/30059-spotted/page/589/#findComment-4879125
haha yeah the thread for name changing is in the ideas and feedback section... I don't mind doing it for you guys though, not like I'm swamped with requests lol
Spotted a silver R33 at the Actew Ecowise building in Fyshwick
https://www.sau.com.au/forums/topic/30059-spotted/page/589/#findComment-4880236
Heh, won't be Actew Ecowise for much longer.
https://www.sau.com.au/forums/topic/30059-spotted/page/589/#findComment-4880275
If I recall the email that went around the company a lil while ago, Actew is selling it's part of Ecowise.
Interesting... I work for Ecowise-Services, About 10 years ago Actew sold it and now its private.
They must be doing the same thing to Ecowise-Environmental
Spotted white 33 with tri-spoke rims in fyshwick just now
https://www.sau.com.au/forums/topic/30059-spotted/page/589/#findComment-4881353
spotted a Lime green R33 and a black R33 with heaps of decals at Rh. green r33 got pulled over by the cops :P . and also saw the cops taking heaps of pics of some dead guy when i was driving back to narrabundah.
https://www.sau.com.au/forums/topic/30059-spotted/page/589/#findComment-4882845
Also W1ngnut and someone in a gunmetal 32 with an SAU sticker that I haven't seen/met before both on Monary hwy this morning.
Haha spotted Trozzle and Bullet32 on Monaro this morning. Does anyone else think the roads might have a lot of dust/dirt on them? I felt like i had very low grip on the way to work and I don't think the 595's are due to be replaced already..
https://www.sau.com.au/forums/topic/30059-spotted/page/589/#findComment-4883144
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
